Old 06-09-2016, 04:10 PM   #11
Briorick's Avatar
Originally Posted by OldCoot View Post
Would have, could have, should have. It's a done deal, now to get it fixed is the OP's situation.
I'm wondering myself how all this would have, could have, should have advice is going to help the OP, other than bring his spirits down. Thankfully he already states it is documented and repairs will be fixed. Just hoping they "fix it right"!
This info would be more helpful. JS.
Rick & Brian
1 Happy Camper Pup ( Mya )
2016 Salem Cruise Lite 171RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 06-09-2016, 04:23 PM   #12
Flybob's Avatar
I would insist on an extended warranty at least on that side of the TT. Tell them they don't know how long the holes were open to the weather. At a min I would insist that CW sched you in for an immediate appointment to fill/seal the holes. A little cosmetic damage is one thing, I wet wall is another.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 06-09-2016, 05:19 PM   #13
Wobbles's Avatar
What is on the inside that could have been added? Is that the bathroom?
Wobbles is online now   Reply With Quote
Old 06-09-2016, 05:27 PM   #14
We had 2 holes drilled thru the side of ours,the factory covered them with tire tourqing stickers.When I "de stickered " the trailer,there they were! I took pictures and just included them with the 20 other items that Haylette RV screwed up/missed,includeing a baseball sized dnt in the skirting.The trailer was at the factory all winter,they did a comendable gel coat repair on the holes and replaced the skirting,among other things.
trbomax is offline   Reply With Quote
Old 06-09-2016, 05:43 PM   #15
I would bet those holes line up perfectly with some white plastic push pin anchors used on the top edge of the shower surround inside.
Mr Havercamp is offline   Reply With Quote
Old 06-09-2016, 07:59 PM   #16
Camping World accepted the holes and probably taped them. Who knows how much water got in before the holes got taped. Good luck with the inside wall, once moisture gets in wall paper bubbles and mold grows. Had to have the rear wall totally replaced because rear window wasn't sealed properly (took a year to bubble - replaced under warranty). Just think replacing the whole wall - could take awhile and you have to hope the insides match when they're done. Don't keep it too long.
D. J. Schuler is offline   Reply With Quote
Old 06-10-2016, 03:23 PM   #17
SilhouettePenny's Avatar
How about mounting an ODS light in that area, since the wiring holes are obviously provided. The dealer would probably be glad to toss you one at no cost. Wire it to an existing light switch on your control panel, problem solved.
1999 F250 w/7.3L Diesel
2014 Silhouette 299RKDS
Nights Camped 2016 - 21
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 06-15-2016, 08:21 AM   #18
Depending on how large the holes are, its not very likely that much rain could have entered the wall. I would see if CW or the manufacturer would come across with a couple of motion sensor lamps and warrant any future water damage.
Rockwoodjoe is offline   Reply With Quote
led, trailer
