Old 05-28-2016, 07:13 PM   #31
northstar1960's Avatar
Originally Posted by awhitlow2000 View Post
If on a septic tank be sure you clean the tank out on a regular (3 to 5 year) basis due to some of the chemicals used in holing tanks of RVs.
Naw don't think so . don't know where you come up with your 3 to 5 yrs . maybe a small 250 gallon tank . but most tanks are 1000 and depending on usage say a family of 4 about every 7 to 10 yrs . dumping your rv BT into your septic will not harm it in anyway . none of the chems used in the black tank will cause any harm either
northstar1960 is offline   Reply With Quote
Old 05-28-2016, 07:20 PM   #32
Originally Posted by emtp82 View Post
Out of curiosity, sometime in the future we may purchase a neighbor's property, can the sewer clean out for a residential property be used as a dump station? I am assuming they are basically the same thing. That would make life a bit easier and convenient for us and friends.
The one thing to consider is which why is the clean out plumbed , toward the house or away ? they use a sanitary sweep tee for clean outs and normally head toward the house so if there is a problem they can run a auger/ snake in toward the house to clear any issues . if done correctly that's the way your clean out faces . some get it done even better by having 2 clean outs next to each other one heading out and the other heading in . if yours isas i suspect it runs back toward your house so when you dump it will force the sewage up stream and then it will stop by gravity and start going the correct way and that may cause a clog
Old 05-28-2016, 07:21 PM   #33
Andy & Ann
awhitlow2000's Avatar
From past experience and was told if you don't have a separate grease trap this is best.
Keeps the grease build up out of the lines from the tank. Our last house had a 250 gal grease trap cleaned it every 2 years. you wouldn't believe the amount of grease build up and we are extremely careful about what goes down the drain.
awhitlow2000 is offline   Reply With Quote
Old 05-28-2016, 07:27 PM   #34
Hog wash ! i've dealt with and installed many a septic system and leach fields
over 30 yrs experience . someone is taking you for a ride .
Old 05-28-2016, 07:39 PM   #35
Campground host Mo. State
Photogirl's Avatar
we also have a storm sewer at the other end of our driveway,but i will check you have me wondering now.
Frank & Kathy & Daisy 2.0 Yorkie (Pack leader)
2008 Ram 6.7 Diesel, 4.10 diff., EGR valve delete, MBRP straight exhaust, Mini Max race tuner, K&N
2016 Crusader 321 RES Ham call W0FCG
Days camped in 2015- 111 in 2016-75 in2017-61
Photogirl is offline   Reply With Quote
Old 05-28-2016, 08:33 PM   #36
Flovern
I use the cleanout with no problems.
2011 Coachmen Sportscoach
flovern is offline   Reply With Quote
Old 05-28-2016, 11:10 PM   #37
Built a big addition on the house about 30 years ago that included a bathroom. The sewer line ran around the house and connected to the existing sewer line in front of the house. Since the neighborhood had a major problem with tree roots I had three cleanouts put in. One is in the back, one is at a turn under our drive and the third is where the connection was made to the existing sewer line in front. Over the years they have proven handy in dealing with problems and have saved me a bundle of cash. Never thought I'd ever use any of them for a rv dump but they sure are handy. I'm putting the same thing down the line that I would from my house. Is is legal? Never bothered to ask and I'm not going to stir up a hornet's nest by asking now. Only use it when I return from a camp that didn't have a full hookup and the dump at the exit was busy. Can't see that I'm doing any harm and it only take about 5 minutes. Have never had a problem. Probably helping the existing sewer by flushing out the buildup.
Bottomline is offline   Reply With Quote
Old 05-29-2016, 10:16 AM   #38
hbdiver's Avatar
Do any of the cities, with ordinances against using sewer connections, provide another means of dumping? It seems that as more people buy Rvs there are less dump stations. In California they have been removing dump stations from the rest areas as well. I have found areas along roads that appear to be the residue from some people just dumping on the ground.
If communities make it illegal to use your own clean-out to dump they should provide a place for you to dump.
hbdiver is offline   Reply With Quote
Old 05-29-2016, 10:33 AM   #39
JohnF's Avatar
[QUOTE=PHS79;1209511]Here is my take on it, as I am a Wisconsin state certified water and waste water operator.
Can it be done, yes. Is it legal to do it, depends on the city/village/town ordinances where you live, but more than likely it is illegal. The village were I live and work it is illegal to use the sewer lateral clean out of anything other than maintenance to the lateral. This was actually a topic of discussion at one of our meetings/classes this past year.
The reason for it being illegal is because there has been cases people dumping such things as motor oil, vehicle antifreeze, gasoline and other harmful chemicals down the clean outs. Doing such things like this will cause major problems in the sewer mains and at the treatment plant, there are two citys within 30 miles of ours that have had to do a complete restart on their treatment plants within the last year because of gas or motoroil being dumped into the city sewer. This process ends up costing thousands or even tens of thousands of dollars in damage and man power to get everything back up and working correctly.
Granted what you are talking about won't hurt anything, but it is more than likely illegal to do.[/QUOTE
Why not just make it illegal to dump anything but raw sewage into a sewer line instead of cutting off this resource to all rv's? It's likely the idiots who dumped oil etc. into the line will continue to do it if it's made legal or not. Imo
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 05-29-2016, 10:54 AM   #40
dbarr's Avatar
Don't know what Peoria IL's ordinance is but they do have a public dump for those who know where it is.
I have used my clean out at the end of the year for a good flush.
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....52
dbarr is offline   Reply With Quote
