Old 02-23-2010, 06:48 PM   #1
wilksfam's Avatar
Honda companion or not
This might go in the tech area, but i'm still learning the ropes here.
Question is what would be the better 1st generator, the Honda EU2000i or EU2000i companion? Some of the info i've found on the internet has been vague. My understanding is that they are the same except for the 30A recepticle. Any input would be appreciated.
Thank you, and everybody keep posting the good info.
wilksfam is offline   Reply With Quote
Old 02-23-2010, 07:14 PM   #2
NWJeeper's Avatar
First off welcome to the forum.
You can't go wrong with Honda generators in my opinion but I would want the 30amp receptacle if it were me.
Ed & Wendy
www.nwjeepn.com
Old 02-25-2010, 07:11 AM   #3
rsl
I have ordered and am waiting the arrival of my Honda EU2000, EU2000 companion, and parallel cable kit. I was told by the dealer you would only get the extra 10 amps (for a total of 30 amps) from the 30 amp socket on the companion if you had 2 of the generators hooked in parallel.
rsl is offline   Reply With Quote
Old 02-25-2010, 07:42 AM   #4
If I'm not mistaking the 1st gen is 13.3 amps and the second would give you 26.6 amps.
2010 Sandpiper 300BH
2009 GMC 2500HD Crew Cab Short Box Duramax
Max Power is offline   Reply With Quote
Old 02-27-2010, 08:58 AM   #5
acadianbob's Avatar
To me it is logical to NOT buy the companion first. Why spend the extra money for it if it turns out you don't need the second one. You only need companion if you have 2 generators in parallel. Buy it last, if you need it.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 02-27-2010, 11:00 AM   #6
wilksfam's Avatar
thanks for the input. I tend to research things to the point i'm back at square one.
Old 02-27-2010, 11:30 AM   #7
I was thinking the 30a recp. was on the paralel cable assembly.They should be wired paralel not in series to increase amps.I have an eu2000 and love it.Powers everything but the a/c.
rsbamafan is offline   Reply With Quote
