Old 04-26-2016, 07:18 PM   #1
Hook up propane grill
I have a 2015 Berkshire Xl that came equipped with an auxiliary propane hookup.Do I use the regulator that is on the grill or remove it and let the regulator on the coach run the grill?
james m rainey is offline   Reply With Quote
Old 04-26-2016, 07:44 PM   #2
flymhi's Avatar
The regulator on the camper is already reducing the pressure. The grill regulator would be removed.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 04-26-2016, 07:45 PM   #3
You have to remove the regulator from the grill. Most decent sized dealers will have the necessary fittings to make it work. There is also a kit that has the hose, required fittings and a control valve. It's not hard to do.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
larryo is offline   Reply With Quote
propane
