Old 06-01-2016, 11:25 AM   #1
Who Dares, Wins
doc73's Avatar
Hooking up 5ver
So I do not have a 5er so I have NO IDEA how to actually use one/ hook one up.. But this past weekend I had a nice 5er (Montana with a bunk house) next to us.
When it came time for him to pack up.. Never mind the sewer hose coiled into the rear compartment... Then the drinking hose payed on top!!!
When he went to hook up.. He put out his tow mirrors on the Ram... And without doing anything else used its name sake and RAMMED the truck under the 5er!
I was shocked! The whole trailer surged backwards, broke one of the x chocks in the wheels, knocked it off its level blocks. Luckily the site was level or I could imagine things could have gotten worse. He did this a few times until the truck sagged under the weight and the trailer lifted off the ground. Then I guess he could not gets the thing to latch because he backed up, pulled up (dropping the 5er back to the ground) and started the ramming again! Three or four of us sat and watched from our sites until their was a loud bang (like a gunshot loud) on the final ram and he got everything hooked up! WOW!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-01-2016, 08:24 PM   #2
It is very easy to hookup a 5er. It only takes about a minute or two. I back up to where I am lined up to the pin. I lower my tailgate and back up until the pin is a few inches from the hitch. I check to see if pin is high enough to easily go into the hitch. I put the handle down on the hitch to lock the pin when it enters the receiver (?). Then I slowly back up until I hear the pin get locked in place. I then retract the the jacks and I'm good to go.
Duane & Jan
2016 Crusader 295RST FW
2011 Toyota Tundra iForce 5.7 Limited Double Cab 6 speed automatic 4.10 gears
djeirlessr is offline   Reply With Quote
Old 06-01-2016, 09:05 PM   #3
Boy was he doing it wrong. Hooking up is the only thing I miss about my last 5th wheel. On a half decent site all you would hear is a low clunk followed by a high ping and I was locked in.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 06-01-2016, 09:24 PM   #4
CaptnJohn's Avatar
I have an aluminum 5er tailgate so I just eyeball it close, check for height of pin and back up slowly. Listen for the light clang, look again and add the lock. Now ready to hold the trailer break and try to go forward ~~ just another check to see we are properly connected ~~ done. Takes a total of 3 minutes. No bars ~~ nothing to do but raise the landing gear (push a button, nothing like auto-level), but away the chocks, and leave.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 06-01-2016, 09:29 PM   #5
Sounds to me (yes I am a retire OTR driver) that he has seen semi's or drove them & yes that is the way you hook them up. But in saying that those trailers have the parking brake that locks so the trailer can't roll. Sooner or later he will have is 5th roll away on him. Not fun!
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 06-01-2016, 09:32 PM   #6
The instructions with my hitch tell you to set the trailer slightly lower than the top of the hitch plate so that the trailer rides the plate up when the truck is backed up. I set it about 1/2" below and I never have any trouble hitching up. The latch pops in and I only have to flip the lock latch into place. It's a Mopar 25 hitch
RV- 2014 Thunderbolt XLR 386X12 Called "The Castle"
TV- 2013 Ram 3600 DRW Diesel Called "Hercules"
rick42wood is offline   Reply With Quote
Old 06-01-2016, 09:44 PM   #7
Our 1st toy hauler last year was a hitch pull that 6 weeks later turned into a 5th wheel. As everyone on here has already said, hitching a 5th wheel is soooooo easy. For that reason alone I will never have another hitch pull !!!
gilwilliams101 is offline   Reply With Quote
Old 06-01-2016, 09:57 PM   #8
B and B's Avatar
If you have Reese Revolution and use it make sure sure you grease the pin, plate, throat and wedge. Makes all the difference in the world.Add grease to any hitch as well.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-01-2016, 09:58 PM   #9
asquared's Avatar
I have seen others slam into their hitch. Totally unnecessary. I ease back while DH adjusts the height as needed (or if alone I will get out and check). Lined up and correct height it slides right in and you get a click. hop out close the jaws, plug in pigtail and hook up emergency break away cable. Raise the landing gear a couple inches, do a quick pull test to ensure not high hitched. Raise landing gear rest of way, pull chocks and good to go.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-01-2016, 10:00 PM   #10
tahoe1840's Avatar
5er
So for many years we towed a conventional and after selling it we pulled the pin, so to speak on a 5er. In the beginning I had nothing but trouble hitching it up because it had the Reese Revolution hitch on it that is very unforgiving. If I was not at the exact height (46 3/4 inches to base of pin) on level ground and if I was not exactly aligned it was a nightmare and took some time to hitch up. After thousands of miles towing my rig it is now super easy to hitch up and in fact very enjoyable to tow. The benefits of towing and backing a fifth wheel are so superior to a conventional. That being said when we sold our first conventional tears came to our eyes since it was such a great travel trailer. In short, time heals all.
tahoe1840 is offline   Reply With Quote
