Old 10-23-2016, 07:51 PM   #1
Obes22's Avatar
Hot water heater
So I just winterized my trailer. I took the anode out of the hot water heater and drained it, but it seems like there is still water in there after draining it. Is this normal? I switched all the valves in the back and the bypass so antifreeze did not go in the tank.
Obes22 is offline   Reply With Quote
Old 10-23-2016, 07:52 PM   #2
SeaDog's Avatar
There may be a little in the bottom but this is not a problem leave the anode out.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-23-2016, 08:02 PM   #3
Ford Idaho's Avatar
As posted already the tiny amount of water left inside will have plenty of room to expand.
If you do chose to leave the anode out fill the hole with a towel or something to keep the spiders and such out of the tank.
I would also suggest you pick up a thread chaser to keep rust cleaned out of the tanks threads.
Old 10-24-2016, 08:47 PM   #4
I take a clean dishrag, push the end into the anode hole a little bit, and let it hang down. Takes a little bit of time, but it wicks most of the rest of the water out of the tank. Put some plumbers tape on the threads and put the anode back in finger tight to keep the bugs out.
2015 Wildwood 28DBUD
2004 Silverado 2500HD tv
Old enough to know better, but young enough to do it anyway.
Jericog3 is offline   Reply With Quote
heater, hot water, water, water heater
