Old 06-08-2013, 06:37 PM   #1
FandRChambers's Avatar
hot water heater
Does anyone know how to adjust the temperature on the hot water heater? My bro in-law has a 2013 Wildwood. He says his water is only warm. Any suggestions? Thanks
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
FandRChambers is offline   Reply With Quote
Old 06-08-2013, 06:43 PM   #2
fonzie's Avatar
Get him to check to make sure his winterizing by-pass valve on the water heater is closed......
Fonzie
Old 06-08-2013, 06:48 PM   #3
Thanks I will do that
Fred & Teresa
2002 EZGO Golf Cart
Old 06-08-2013, 08:07 PM   #4
That's not issue. He is getting water to the hot water heater. Just not getting hot.
Fred & Teresa
2002 EZGO Golf Cart
Old 06-08-2013, 08:14 PM   #5
The water in the tank might be very hot...but if the winterizing valves are wrong it will be mixed with cold water == warm. He can open the over-pressure valve on the water heater to see if the water is really hot (or warm) inside it. If its hot...check the winterizing valves.
Old 06-08-2013, 08:14 PM   #6
Capsfloyd's Avatar
Run it on electric and gas
If not on the wh on the outside door there should be a small dial to turn to make the water colder or hotter ?
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 06-08-2013, 08:18 PM   #7
BillyBass's Avatar
You still have to make sure the value is close bc it will draw cold water to I had to close mind and it is hot now
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 06-08-2013, 08:19 PM   #8
I will have him double check for a switch. I think he looked but his first trailer.
Fred & Teresa
2002 EZGO Golf Cart
Old 06-08-2013, 08:36 PM   #9
sherdep's Avatar
It will be a valve not a switch
The other issue could be scale build up in the hot water tank
Have him pull the anode rod and make sure the rod is good - (it may need replacing) and the tank doesn't have any build up.
Make sure the electric is off and the water is off before he pulls the anode or he could have a potential mess
I always release the pressure with the pressure valve before pulling the anode
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-08-2013, 08:38 PM   #10
sherdep's Avatar
Also have him check to see if the two black buttons are popped - I have a suburban water heater and if it gets too hot it pops the buttons and they have to be reset - usually happens when ran on gas and electric
