Old 12-11-2015, 10:33 PM   #1
CaptainJohn's Avatar
Hot water heater
Newbie question. Do I have to have the breaker on in addition to turning on the switch located on the panel to run the hot water heater??
Camping Newbie
Savannah, Georgia
2016 Flagstaff V Lite WFKSS
CaptainJohn is offline   Reply With Quote
Old 12-11-2015, 10:48 PM   #2
wmtire's Avatar
Howdy CaptainJohn, do you have the Suburban brand water heater? If so, this may help:
http://www.forestriverforums.com/for...ore-36197.html
Also do, you just have one switch on the panel or is there an electric and propane switch?
The circuit breaker only controls the 120 volt AC electric side of a water heater, as explained in the link above
2011 Flagstaff 831 RLBSS
Old 12-12-2015, 08:11 AM   #3
SilhouettePenny's Avatar
If we're talking about heating water with electricity, then yes the breaker needs to be on.....the switch on at the panel ......AND the switch located outside behind the door at your water heater. This one is illusive as mine had silver tape on it making it difficult to see with the silver tank behind it.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 12-12-2015, 08:32 AM   #4
You may want to keep a plastic ball point pen inside the door of the Suburban Water Heater to (Reach the Rocker Switch) behind the propane line! Unless you have Fingers like ET! Youroo!!
heater, hot water, water, water heater
