09-16-2014, 10:58 AM
Hot water heater on electric
Hi all im a newbie snd
Headin out on our first trip next wk, campsite has full hookup so i want to run my hot water heater on electric can please tell me the proper procedure for starting that
09-16-2014, 11:01 AM
We'd first need to know the model and brand of water heater to help you.
Assuming it's a suburban the electric on /off switch is outside your camper.
Remove the outside cover and look in the very lower left corner you'll see a tiny black on off switch. "Hidden"
Make sure your water heater is full before you start it.
BTW didn't they show you this when you bought it?
TURBS
How can I annoy OC today?
09-16-2014, 11:03 AM
All depends on what heater you have. Let us know the model number of water heater and we can go from there.
No matter which kind it is though, always make sure it's full of water by checking with the relief valve before turning on the electric.
09-16-2014, 11:10 AM
Yes the switch is outside on bottom left side
Of heater when i take grate off and there is water in the tank as i checked the relief valve just wanna make sure im doin it right when i plug in to shore power i turn on outside switch as i mentioned above is there any thing else i need to do?
09-16-2014, 11:11 AM
Sit back and enjoy!
TURBS
09-16-2014, 11:12 AM
Nope, that sounds about it.
Either:
1) check for water
2) Plug in trailer
3) Make sure switch is on
Or:
1) Make sure switch is off
2) Plug in trailer
3) Check for water
4) Turn switch on.
09-16-2014, 11:14 AM
Welcome and congratulations.
Just initially before turning on WH, regardless of heating source, be sure to hookup water and open faucets hot and cold to purge air in lines and HW heater. This will ensure that you do not burn up your HW heater or ruin your electric element.
Someone else who has the same unit as you can provide more detailed information specific to your unit.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 Chevrolet 4500
Using FR app
on 2012 4500 Chevrolet Chassis
Paul
09-16-2014, 11:17 AM
Here is a detailed FAQ on the operation of the Suburban brand water heater:
http://www.forestriverforums.com/for...ore-36197.html
One question, is your RV of the 30 amp (3 prongs on main electrical cord) or 50 amp (4 prongs on plug) type?
2011 Flagstaff 831 RLBSS
09-16-2014, 11:18 AM
Paul
Using FR app
Actually your method shouldn't be used.
Here's why.
If you use the hot and cold tap to purge air from water heater "it's possible" that the water heater bypass is turned "not allowing " water in the tank giving the allusion that there is by getting water from your hot water tap.
You should always use the pressure relief valve to purge any air.
Mine is always open while the tank is filling.
Just an fyi.
TURBS
09-16-2014, 11:19 AM
30 amp
09-16-2014, 11:20 AM
IF the wh is in bypass (winterizing) mode, turning faucets on won't do it. The only safe way to insure the tank is full is opening the pressure relief valve until water pours out of it.
Just a guess but a (2004 Salem) might NOT have a (Gas/Ele) W/H? Just guessing like everyone else! Youroo!!
09-16-2014, 11:21 AM
Yes it does have both
09-16-2014, 11:23 AM
30 amp
Thanks, your RV being a 30 amp type, you will need to be mindful of other electrical things you run at the same time, as the electric element uses 12 amps (of the 30) when heating......as you may trip the circuit breakers.
It's explained in edit #2 in the link I provided previously. You will get it all figured out, and feel free to ask any/all questions you want. That's what the gang is here for.
09-16-2014, 11:24 AM
Youroo just an fyi.
There either gas only or gas / electric
TURBS
09-16-2014, 11:25 AM
Now if you post the Mod# and MFG.of the W/H it will help! Youroo!!
09-16-2014, 11:27 AM
I will post when i get home from work
Originally Posted by f1100turbo
Youroo just an fyi.
TURBS
Thanks,Thats what I said! Youroo!! They come with a Gas only,you have to spec a G/E back then!
09-16-2014, 11:34 AM
I know it is both cause ive had it running on both just wanted a refresher on how to run it
09-16-2014, 11:36 AM
Have fun!
Fall camping is the best!
TURBS
