08-02-2016, 09:39 PM
Hot water heater question
I have a 2016 Forest River Wildwood. My question is, why is there a hot water switch on the panel where the other switches are (i.e. slide out, awning, light switch, etc.) but having the switch OFF does NOT turn off the hot water heater. The only way I can turn off the thing is to flip the circuit breaker or else it stays on all the time. I can't tell that the switch does anything but turn on a little red light above the switch.
Thanks,
Lodie
08-02-2016, 09:48 PM
I don't have a Wildwood, but it's probably the same as mine. The switch on your panel turns on the gas function of the water heater. If you go outside and remove the cover panel on the heater, you will see a switch in the lower left corner. That turns off the electrical function of the heater. If you want a fast recovery during multiple showers, leave both switches on.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
08-02-2016, 09:49 PM
I think you have a gas/electric water heater. I think the switch on the panel turned off the gas side. On my water heater, there is an electric switch to turn off the electric. My switch is located outside. Remove the panel and look to the lower left. It may be hidden a bit behind the gas piping. It will work with both. Most people use the electric side to save on propane and switch on the gas when fast recovery is needed. Hope this helps.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
08-02-2016, 09:55 PM
Thank you for that. I've never seen anything about this in my owner's manual. This makes perfect sense and I'll check it out tomorrow to see what happens. Thank you for your reply.
08-02-2016, 10:02 PM
Thanks for that. I think I lost all my individual appliance operating instructions. Guess I can find them on line somewhere.
08-02-2016, 10:42 PM
Lodie:
Look at the pics in post 29 here:
http://www.forestriverforums.com/for...h-49540-3.html
Shows you where the switch is on the outside of the water heater.
You may or may not have the safety pin through the switch. (Mine doesn't).
2011 Traverse LT, 3.6L, FWD
08-02-2016, 10:50 PM
You most likely have the Suburban water heater. This FAQ on it should get you all lined out. Let us know if you need more help:
http://www.forestriverforums.com/for...tml#post327988
2011 Flagstaff 831 RLBSS
08-03-2016, 04:19 AM
Good answers people!
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
08-03-2016, 12:35 PM
Just remember to make sure your hot water heater is full before using the electric switch. If you don't you will ruin your tank.
On the gas side if the little red light above or next to the switch comes on it means there was a fault while lighting. Cause could be propane is turned off or possible air in lines. Once gas reaches heater it should light.
Good Luck!!
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
08-03-2016, 12:37 PM
Thanks,
Lodie
It's a water heater. Not a hot water heater. You don't heat hot water. It's already heated
08-03-2016, 01:12 PM
LOL!! At what point is the water considered hot? So at some point you are heating hot water to become hotter water. 😁
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
08-03-2016, 01:14 PM
Originally Posted by NMWildcat
LOL!! At what point is the water considered hot? So at some point you are heating hot water to become hotter water. [emoji16]
Same could be said for the other was as well [emoji16]
08-03-2016, 01:37 PM
I'm usually the one that says that, but don't think I didn't want to say it!
08-03-2016, 01:38 PM
So it's a hotter water heater!!! I like it!
You won't really ruin your tank by turning the electric switch on without water in the vessel, but you will ruin the element in a few seconds.
Gotta go campin!
08-03-2016, 03:38 PM
That's funny... but true I Suppose.
08-03-2016, 08:35 PM
Yeah, we know! (It's REALLY a cold water heater!)
