Old 11-23-2014, 01:54 PM   #11
Replace the shower head with an oxygenics. It will be a water miser and save your hot water making a quicker recovery. I have a small hot water tank and have never ran out of hot water when taking a shower. Takes only a few minutes to replace and you will be glad you did. Your local camping supply store or Camping World will have them.
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
JohnandPandra is offline   Reply With Quote
Old 12-11-2014, 10:05 PM   #12
jtrader's Avatar
In the winter the temp of the water supply is lower to begin with. I've measured 35 degrees out of the cold tap in January. I use a residential shower head and put up with a little less water pressure by not turning the hot on full blast and using only a trickle of cold to make it a comfortable temp. This makes my typical shower run 4-5 minutes in the dead of winter (10-20 degrees outside).
My TT: 2013 Cherokee Grey Wolf 28BH
jtrader is offline   Reply With Quote
hot water, water
