Old 07-18-2011, 05:24 PM   #11
grhodes50's Avatar
Originally Posted by chromeOkie View Post
noobie here, drained my hot water tank the other day and I only have a plug with no attached inner rod. do some tanks not use this device? thanks
Prime Time trailers have the Atwood water heaters, so no anode rod. Just a plastic plug.
Gary & Trish
2018 Nights Camped - 5
Old 07-18-2011, 05:51 PM   #12
ilmor's Avatar
I change mine each year as recommended by water heater the manufacturer - cheap insurance.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-18-2011, 05:56 PM   #13
chromeOkie's Avatar
thanks, this forum helps alot
2011 F150 Ecoboost FX2 Screw 6.5 bed
2012 FR Tracer 230FBS
chromeOkie is offline   Reply With Quote
Old 07-18-2011, 06:23 PM   #14
caper's Avatar
New rod $ new water heater $$$. Your choice. The anode rod is used so that the anode rod will break down and not the tank of the water heater. Mine was about 50% gone when I replaced this year. Many people spend thousands of dollars to purchase a new TT the nickel and dime afterwards trying to save a few cents each year. Even if you replaced the rod every year at $10 you could be saving the cost of a new water heater a few years down the road.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 07-18-2011, 06:35 PM   #15
Herk7769's Avatar
I have NO problem spending money on my camper.
However, I am in the less than 50% camp.
Spend money... Don't waste it.
As to the OP's anode, I would replace it as well. It looks ready. What you do not want is the anode to be so honeycombed as to start breaking off pieces. Those pieces will eventually clog all your faucets and we will wind up posting about water pressure in the plumbing forum.
HAM CALLSIGN - KC3FFW
Old 07-18-2011, 08:20 PM   #16
It already looks like some chunks have fallen off the anode. I change mine long before it looks like that one. Why take the chance for a lousy ten bucks?
Old 07-19-2011, 06:46 AM   #17
KyDan's Avatar
The anode in the photo is still good.
As someone said, as long as there is material on the rod it's working.
I'll spend the $10 on a few cold ones
and replace mine when it looks quite a bit smaller than that one.
MY concern is the threads in the anode hole rusting badly over the
winter while it's winterized with the anode plug removed..... how do
you combat that
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-19-2011, 08:48 AM   #18
jimh's Avatar
Thats what mine looked like when I pulled it for the first time. Its going to depend on the minerals in ur water as to how long it last.
When u replace, there is a difference in the plug size between atwood and surbain.
I believe the anode is only in the heaters with an electric element.
U have a little more life left in that one but u have it out, id go ahesd and change it out.
Mine was pulled for the first time this past fall.
being as far south, I didnt drain the waterheater. Will propably make an annual event now...it got colder than normal here this past winter. Didnt know that when I drained it.
jimh is offline   Reply With Quote
