Old 07-18-2011, 03:41 PM   #1
Athens-M50's Avatar
Hot water plug????...is this normal?
Hey Guys...Just got home today from a camping trip....and noticed my Hot water plug was leeking....so when I got home...I took it out and saw this???....is this normal?.....is this just build up?....do I need to knock it off and put some dope on it and screw it back in?
Name:	Hot water plug.jpg
2002 17' Shamrock
2001 F150 Ext Cab
________________
2012 nights camped 6
Athens-M50 is offline   Reply With Quote
Old 07-18-2011, 03:46 PM   #2
MtnGuy's Avatar
Do not knock that stuff off !!! That is your anode rod. It is normal looking. It is meant to deteriorate through a galvanic exchange process.
If that is the orginal rod in your 2002, then you are doing good. You probably have a couple of more years left on that rod. Wash it off with clear water, put some teflon tape on the threads, and reinstall the rod. It is a good idea to pull the rod out once a year to inspect it.
This is mine after just 2 years of use:
Old 07-18-2011, 03:49 PM   #3
Athens-M50's Avatar
Thanks....so how do you know when it is time to replace?....
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 07-18-2011, 03:54 PM   #4
DAISY BOYKIN's Avatar
Replace it !
Looks like the anode (zinc) rod is just about had it. It should be replaced.
Looks like about 60% of it is gone. If it were mine, I would replace it. If you continue to use it in the shape it is, your tank will start to break down next.
How old is the anode? If you camp regular during the season or do not drain your hot water tank during the winter, it will speed up the deterioration of the anode.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 07-18-2011, 03:58 PM   #5
MtnGuy's Avatar
You can replace it now, if you want to. The replacement rods are about $10 or so at your local RV store. Inexpensive insurance insurance to protect your water heater.
I am planning on letting mine get down to about 25% before I replace that puppy. Having less of the anode does not decrease it's effectiveness. But not having any anode on the rod is not a good thing, so you don't want it to be completely bare.
Some members here replace their rod every year. I am cheap.....if it is still working, that is $10 I will save that year.
Old 07-18-2011, 03:59 PM   #6
MtnGuy's Avatar
Not too sure about that, Sid.
Old 07-18-2011, 04:07 PM   #7
Villa Estate 392FLFB
The_Stuff's Avatar
got it out might as well change it up.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 07-18-2011, 04:07 PM   #8
Athens-M50's Avatar
Just bought the camper....so I don't know how old it is....may pick one up....not sure.
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 07-18-2011, 05:03 PM   #9
chromeOkie's Avatar
noobie here, drained my hot water tank the other day and I only have a plug with no attached inner rod. do some tanks not use this device? thanks
2011 F150 Ecoboost FX2 Screw 6.5 bed
2012 FR Tracer 230FBS
chromeOkie is offline   Reply With Quote
Old 07-18-2011, 05:18 PM   #10
MtnGuy's Avatar
Yes. I don't think the Atwoods use an anode rod.
Bout time to get out the instruction manual to be sure, though.
