Old 09-07-2014, 08:03 AM   #1
BuckeyeChuck's Avatar
Hot water sulphur smell
Every so often we get a sulfer smell from our hot water. If I turn off the heat and let it run for ten minutes or so the smell goes away. Any ideas about what is causing this?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 09-07-2014, 08:12 AM   #2
Ford Idaho's Avatar
Anode rod or the water it's self, are you on a well or treated?
Last time the water heater tank was flushed and the rod checked?
Old 09-07-2014, 08:18 AM   #3
RudysWorld's Avatar
I had a neighbor at a campground with the same problem. I found this online:
Rotten egg smell in the hot water.
One of the fun things about RV repair is it is very common to find varying opinions about solutions and causes for the same basic problem. I have found three different techniques to this problem. The cause always seems to be pretty much the same however.
Cause: Sufficient amounts of sulfur in the water to produce an odor. This is caused by the electro-galvanic action of either the special 15% thickness of the type 7072 aluminum (pure aluminum and zinc) that is fused to the inside of Atwood tanks since 1988 or the anode rod in the Suburban. Bacteria in either brand can also cause it.
Step 1 : Turnoff the water heater and let water cool if need be.
Step 2 : Drain and flush the tank. By flush I mean let fresh water run through the tank quite awhile and get out all the sediment that can settle in the bottom of the tank. The agitation action of the water coming into the tank should help unsettle and flush the sediment. Compressed air can also agitate the sediment or you can use a bent stiff wire or brush and go in through the drain hole to stir things up. If you do this be careful not to damage the threads. This is also a "tool" available in most RV stores that hooks on the end of a water hose and is specifically designed for this purpose. The primary objective here is to get the sediment out. I might also advise to be certain the water you use to flush does not have a sulfur odor. Keep the drain hole clear as the sediment can stop it up.
Step 3 : (optional): Remember the varying opinions? Here is one. Fill the tank with 2 parts distilled vinegar to 1 part water and let set at least 2 hours. That is a lot of vinegar! I checked to be certain my manual did not have a misprint and that is the correct ratio. Let it sit for a couple of hours and rinse with fresh water. To fill the hot water tank only you must go through the T&P valve (the valve on the top of the outside of the tank with a lever and metal tag on it.) Screw a male fitting into it and let gravity feed the solution in through a funnel and flexible hose (open a hot water faucet to let air escape). You can also go through the drain valve or anode rod opening using the same procedure. You can open the T&P valve to let air escape. Be sure to hold funnel/hose high. The third way is to pump it through the fresh water system. This will also pump the vinegar water into most of the rest of the system. You will need to flush real good before proceeding to the next step.
Step 4 : (optional): Add about 4 teaspoons of household detergent for every 10 gallons of water into the fresh water tank. If you will add a little detergent then water then detergent then water, and so on this will help mix the solution. Run this solution through your whole water system (all faucets, valves, and toilet). Use your water pump and continue putting in water and pump through until the detergent is gone. Be certain to remove faucet aerators and shower heads during this procedure. Clean and reinstall them before the next step.
Step 5 : (recommended option): Do the same as step 3 using common household bleach at 5-6 ounces (2/3 to 3/4 cup) per 10 gallons of water. You might let this set in the system for a couple ours to a few days. Then flush out till chlorine smell is gone. Some people advise this step may need to be repeated several times.
As you can easily see, Step 4 & 5 also help freshen your whole system.
Step 6 : When you are convinced you have all the vinegar, detergent, and bleach out, close the system and refill the water heater and the system. To fill the water heater correctly you should follow the instruction in the next section.
Good Luck!!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 09-07-2014, 08:19 AM   #4
mud yapster's Avatar
X2 drain and flush the hot water tank and check rod.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-07-2014, 09:18 AM   #5
Director, FROG
F.R.O.G.'s Avatar
When you winterized last year, did you close the input and output pipes to the water heater and open the crossover to keep anti-freeze out of the tank? You need to be sure that you do that. Letting anti-freeze in and then not getting it completely flushed out before you turn on the heater will produce the smell you're describing.
Follow the suggestions above to flush.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 09-07-2014, 09:21 AM   #6
Sounds like VOE.
Old 09-07-2014, 09:25 AM   #7
Director, FROG
F.R.O.G.'s Avatar
Not my own experience, OC, but that of a good friend who "educated" everyone in our Coachmen club in St. Louis when he parked upwind on the first campout of the spring.
Bob Byrne
Old 09-07-2014, 09:29 AM   #8
Herk7769's Avatar
While the sulfur smell could be caused by "Sulfur water" it is most likely being caused by bacteria growing in your water.
The answer is to sanitize your system.
Excerpt from the manual.
Name:	Odor From HWH.jpg
HAM CALLSIGN - KC3FFW
Old 09-07-2014, 09:33 AM   #9
Sounds like the education I got years ago in Knoxville, Ia with tying down manual awnings. Friends got pretty well damaged sitting next to us. Lucky ours didn't as it wasn't tied down either. It sure was the next morning and every time it was deployed after.
Old 09-07-2014, 10:07 AM   #10
I have not drained the tank this year. I will try draining and flushing the water heater then do the bleach sanitizing step.
2013 Sabre 33CKTS
hot water, water
