Old 05-10-2018, 09:18 AM   #1
Hot water tank mistake
Dumb mistake but turned on hot water electric thinking it was full but I had the bypass on. Electric is not working (warms only not hot) but gas is ok. Can I replace electric heating elements or do I need to replace the unit. Also what is the best way to access on 35rok sandpiper. Thanks
gcamp is offline   Reply With Quote
Old 05-10-2018, 09:20 AM   #2
SeaDog's Avatar
More then likely you burned the electric heating element and will need to replace it but not the whole unit.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-10-2018, 09:22 AM   #3
wmtire's Avatar
You can replace the element, but it depends on what brand water heater you may have, as to how hard a job.
Do you know if it's a Suburban or Atwood brand (a pic would easily show which if you don't know)
Suburban elements are in the front of the water heater (easy to replace) while Atwoods are accessed from the rear (more difficult)
Another way to differentiate brands possibly, is where the switch was for the electric heating element (inside the RV or outside on the face of the water heater)
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 05-10-2018, 09:33 AM   #4
Thanks for the help. I havenít got to the heater yet. Still trying to figure best way to get at it. Electric switch on/off is outside next to drain plug.
Old 05-10-2018, 09:35 AM   #5
wmtire's Avatar
OK, that tells us it's a Suburban brand. Easy enough.
Here's what you need:
Suburban water heater electric element R&R
Old 05-10-2018, 09:54 AM   #6
Thank you!!! Iíll will get the part order and let you all know how I did. Sure is nice to have your help... saved me a new tank and maybe a service call.
Old 05-10-2018, 12:36 PM   #7
DouglasReid's Avatar
You can actually get one from any RV supply place.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 05-10-2018, 12:45 PM   #8
DieselDrax's Avatar
Or virtually any Home Depot or Lowes for under $10.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is online now   Reply With Quote
Old 05-10-2018, 01:37 PM   #9
Carknocker Family
Ida Ratherbe Camping's Avatar
Lowe's or Home Depot, would be my choice
Ida Ratherbe Camping is offline   Reply With Quote
Old 05-10-2018, 01:56 PM   #10
Amazon or eBay also
Amazon or eBay also. Don't forget the wrench.
Larry
Larry-NC is offline   Reply With Quote
hot water, tank, water, water tank
