01-13-2018, 05:45 PM
House Batteries in or out for storage
Here in MN the temp is -10 degrees. My Class C Forester is in outside storage with the house batteries in place. I have been starting the RV every 2 weeks or so to hopefully maintain the charge. That seems to work. However, is it better to remove the house batteries and place them on a Battery Tender to maintain until Spring? Thanks for the advice.
01-13-2018, 06:03 PM
Use a tender with batteries in place or out. Your choice. Your starting and idling is a waste of fuel. Most say just place a 100-watt lightbulb on in the battery area.
01-13-2018, 06:07 PM
If they are lead/acid batterys charge them to 100% with a battery charger then disconnect a battery cable, they will keep the charge for months.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
01-15-2018, 03:32 PM
Moved mine to the garage and on a Battery Tender till Spring.
[IMG] [/IMG]
<(((>< Forest River Rockwood Mini Lite 2109S ><)))>
01-16-2018, 03:12 AM
And just so you know, they can sit on the concrete just fine.
01-16-2018, 01:20 PM
What this person said...
we get - 40 degree temps here. bring mine in and do the same.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
01-16-2018, 02:09 PM
I am able to run an extension cord to my Georgetown to keep batteries charged over winter. Check water periodically.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
01-16-2018, 02:10 PM
wbmasche, I have a Lance TT that sits in storage all winter. For the Lance's battery, I pull the battery and store it in my garage on a maintainer.
I also have a Georgetown 31L5. Like you, I start my engine every two weeks. But, I also drive it 10 miles or so to warm and lubricate everything. While driving, I also run the generator at load to keep it in good shape. No battery maintainer on the Georgetown.
McCormickJim
2017 GT 31L5
01-16-2018, 02:26 PM
There are so many old wives tales about batteries that are simply not true yet people still believe them.
Like the two posters above said... charge them up, unhook the cable(s) and let 'em go till spring and you'll be fine. No need to remove, no need for tenders, no need for light bulbs, no need for wood under them.
I have been doing this with lead acid batteries for many years (not just in R/V's either) and never had a battery go bad from weathering the winter months this way.
01-16-2018, 02:31 PM
x2 5picker.
My current batteries are 7 years old and have never seen in inside of a building or a battery tender and they are doing just fine.
01-16-2018, 02:50 PM
I do the same for the house battery. I also connect a solar charger to the dash cigarette lighter to keep the engine battery charged.
I have been wondering, do you have to disconnect the chargers/solar panels when you run the engine, meaning will the alternator's power damage them?
01-16-2018, 05:49 PM
no
Denver, CO
No. no issues with the panel and running the engine.
2017 Fuse 23T
01-16-2018, 05:50 PM
Boondocking is correct. Fully charged to 100% batteries will not freeze till 92 below. In very cold temps like yours...IF you remove the negative cable ...the batts will only lose a few percent a month. If you're nervous about it...put a multimeter on the battery terminals once a month and as long as you read above 12.4Vots...you are fine for starting /running and safe from freezing... even in Minnesota!
________
Cam
2015 Georgetown 280DS
01-16-2018, 08:45 PM
Everything you need to know about wet cell battery maintenance from the foremost manufacturer of deep cycle batteries:
Battery Maintenance | Trojan Battery Company
01-16-2018, 09:27 PM
Thanks but they aren’t there because of the concrete. [emoji106]
01-17-2018, 01:08 PM
Out of curiosity, why?
01-22-2018, 09:52 PM
[IMG] [/IMG]
Hey, put those batteries on the concrete floor. The battery Nazis will be telling you not to put anything under them.[emoji2]
01-31-2018, 03:07 PM
It's much easier for me to check the water level if I don't have to get down on the concrete on my almost 70 year old knees. If I had a work bench, they'd be up there!
02-01-2018, 01:44 PM
Just get some AGM batteries and you will never add water!
