Old 03-10-2012, 03:33 PM   #1
house battery question??????
I was wondering if the house batteries are only charged when the generator is ran, or do they also charge off the engine. (class c 2860ds)
Thanks for any advice.
snowman62 is offline   Reply With Quote
Old 03-10-2012, 03:44 PM   #2
The best way to determine if your engine or gen charges your batteries is to test it with a Volt-Ohm Meter, VOM.
Just because someone says it should doesn't mean it's so.
Check the voltage befor you start your engine, then while the engine is running.
If you see a rise in voltage, around 14.1v- or so, you are charging. If it's the same, no charge is present, but you may not be low, so use some battery power, then start your engine again, check once more.
Mike
traveler2955 is offline   Reply With Quote
Old 03-10-2012, 03:46 PM   #3
Thanks. I will try first chance I get.
battery
