Old 04-03-2015, 08:12 AM   #21
Originally Posted by B and B View Post
Safety Alert. Burning a Propane heater inside the camper creates carbon monoxide. Unless a window and vent is open you could have a build up of CO and loose Oxygen for sustaining life.
Yes, I believe both of us who recommended this option said we crack a window. I think the directions that came with the Buddy heaters instruct that 6 square inches of ventilation is necessary to safely operate one indoors.
We also would turn our Buddy heater off right before we fell asleep for the night just to be safe. The furnace would still run a lot through the night, but at least the Buddy heater saved the battery during all our waking hours.
Another tip for those who cold weather camp with no shore power, use a battery cut off switch (or manually disconnect the battery) when you are out doing activities during the day. The TT will draw a significant amount of amp hours from your battery over the course of days just powering the converter, smoke and CO2 detectors. When you return to camp fire up the Buddy heater on high to heat the TT back up so the furnace doesn't have to do the work.
2012 Grey Wolf DBH
1999 Lincoln Navigator 4X4 5.4L 32v Intech
Ryno22980 is offline   Reply With Quote
Old 04-03-2015, 10:29 AM   #22
driftinby's Avatar
Originally Posted by Life Without Whine View Post
...if you want it, it's yours (short queen)
Wow, really? I think my wife would like that however, I'm not sure if ours is a short queen or regular. I'll know on Monday.
The only way to truly ensure your safety is to bar and lock yourself in your home.
But when your gone and the smoke detector is off, how will you know when your coach is on fire?
2014 Ford F150 FX4 EB
2015 Grey Wolf 26DBH
1994 Palomino TXL
driftinby is offline   Reply With Quote
Old 04-05-2015, 08:22 AM   #23
yetavon's Avatar
Super bowl Sunday last year I awoke on a kayak river trip with the condensation turned to frost on the inside of my tent. It was 27 at 9 AM.
This Feb at a winter rally we stayed comfortable in our HTT when it dropped to 17 overnight. didn't dewinterize and used water from a jug. An small electric heater and propane....and no PUGs
yetavon is offline   Reply With Quote
Old 04-05-2015, 09:45 AM   #24
Phat Phrog Stunt Crew
elind's Avatar
One thing to remember is when it's below freezing your propane furnace is blowing heat to under belly if it is enclosed. If you rely on electric space heaters only, the underbelly won't get heated. We use our electric fireplace and propane heat with our fresh water tank for water.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-05-2015, 11:08 AM   #25
This is true and another reason not to run the buddy heaters while sleeping. Let the furnace do it's job overnight when it's coldest to keep the tanks from freezing. Again though, a tank with several gallons of water would take a long time to freeze even with no heat. It's the unprotected supply lines that are most vulnerable.
Old 04-05-2015, 11:50 AM   #26
You can lock yourself in your home, but something could short out and set the house on fire while you're sleeping.
No, the only way to truly ensure your safety is to kill yourself NOW.
2011 Traverse LT, 3.6L, FWD
Old 04-05-2015, 01:14 PM   #27
elind's Avatar
Another thing you can do in cold over night cold weather with full hook ups is to let your water run. Open your gray water up and then let your water faucet open just a little bit to keep the lines from freezing.
2014 Wildcat 327ck
camping
