Old 09-23-2016, 08:32 PM   #21
jtesta1's Avatar
Maybe Santa chipped it last Christmas
jtesta1 is offline   Reply With Quote
Old 09-23-2016, 08:36 PM   #22
Damn China bomb fireplaces.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
Old 09-23-2016, 10:42 PM   #23
Tempered glass, generally tinted, can spontaneously break. Usually the glass is in an exterior position on a building elevation exposed to sunlight. There is a defect sometimes built into the glass and it's called a nickel sulfide inclusion. It starts off as a tiny flaw but when exposed to sunlight the nickel sulfide inclusion grows until the stress created causes the glass to explode. Sometimes, if the glass remains in the frame you'll see a radial fracture pattern. The nickel sulfide inclusion is at the bullseye and can be seen with a microscope.
Also, the glass generally used for the fronts of residential fireplaces isn't glass but a ceramic that can handle high temperatures.
johng4706 is offline   Reply With Quote
Old 09-23-2016, 11:38 PM   #24
dmchapman's Avatar
We had a similar explosion of a tempered glass table top on the patio at home. It had withstood years of use and standing in the weather but one fine day it just let go. Fortunately DW and fur babies were indoors at the time.
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is online now   Reply With Quote
Old 09-24-2016, 08:02 AM   #25
Oakman's Avatar
The brand of our fireplace is Tec Flame and I was looking through the small manual that came with the fireplace for contact information and found none. As I was reading though the manual I came across this sentence amid a couple of paragraphs under the heading After Sales Service. “Should you require after sales service you should contact our customer service help desk on xxx xxx xxx.” Yep, a bunch of X’s instead of a number. Ya gotta love the RV industry.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 09-24-2016, 08:33 AM   #26
wmtire's Avatar
Evidently this happens, and is probably something all members should be aware of, either for their RV or home products.
An ABC news affiliate did a report on this last year, and it's a pretty good video to watch for educational purposes. The experts/manufacturers state that a defect in the glass can take years to show. (well after a warranty has expired I'm sure)
Experts explain when, why tempered glass can randomly explode - ABC2News.com
Thanks Oakman, for sharing.
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 09-24-2016, 08:50 AM   #27
Cottonwood RV
One of our favorite campgrounds when visiting family in Columbia. Only downside is not having fire rings, so you're out of luck if you want a fire. Good luck in getting it replaced!
gfarmcafe is offline   Reply With Quote
Old 09-24-2016, 09:30 AM   #28
Originally Posted by Rugged Brown View Post
Without a doubt, it's caused by the wind baffling down the chimney...
Hee-hee..that's good one. Every electric fireplace must have a chimney. Maybe it got bumped by Santa on a practice run..
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 09-24-2016, 10:33 AM   #29
Iwannacamp's Avatar
I think this will get you started. I consider myself a pretty good googler. I often have to search for odd and old stuff at work...this was a bit tuff...almost like they didn't want to be found.
Name:	ImageUploadedByForest River Forums1474731165.019594.jpg
ID:	121122Click image for larger version
Name:	ImageUploadedByForest River Forums1474731201.687479.jpg
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Old 09-24-2016, 11:16 AM   #30
Sc00ter's Avatar
Severe temp extremes can also cause tempered glass to shatter. Picked up a window that was extremely cold with my bare hands. The warmth from my skin caused the break.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
