Old 07-01-2015, 04:30 PM   #1
How do I get my toilet clean from calcium build up? Graphic pic
How can I get this toilet clean? I assume it is calcium buildup. I cant scrub the flap hard because Im afraid I will break it but I cant even get this brown stuff off of the walls. Any advice?
gr8white is offline   Reply With Quote
Old 07-01-2015, 07:22 PM   #2
BooBoo23's Avatar
I don't think the "brown stuff" is calcium. Is the bowl plastic or ceramic? I was going to suggest vinegar but that may destroy the rubber seal. Ask a plumber what they would use.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 07-01-2015, 07:31 PM   #3
Looks to be ceramic. I would remove the toilet, remove the valve and clean with whatever will remove the stain. Just don't damage the seals when disassembling or reassembling. Use plumbers grease (silicon-Danco) when reassembling.
Old 07-01-2015, 08:27 PM   #4
Who Dares, Wins
doc73's Avatar
Try toothpaste, works wonders without to much fuss. Just use the DW brush.. Not your own. I've used magic erasers before to get all sorts of stuff off as well.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-02-2015, 12:12 PM   #5
I used dilute vinegar and sealed the drain with plumber putty
I didn't remove just packed around it even with floor
glenn56h is offline   Reply With Quote
Old 07-02-2015, 12:19 PM   #6
jtstromsburg's Avatar
If it's porcelain, try pouring a bottle of coca cola in it and let sit for a while, then brush clean. The phosphoric acid in coke should loosen the buildup. If possible, use a bowl mop, not a bristle brush. Bowl mop looks like a big soft cotton swap. It nearly allows the chemical to work.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-02-2015, 12:26 PM   #7
B and B's Avatar
I just had to scrub my Sea-Land toilet in my trottage. Iron buildup, just used a toilet brush carefully. Toothpaste works on hard lime scale on my taps and I will try it on the toilet next time, thanks for the idea.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-02-2015, 12:32 PM   #8
wnelsonfl's Avatar
may be rust. get rust remover available at any grocery store. if that doesn't work try bleach. soak either of these for a half hour. that isn't long enough to damage seals but will tell you if it is organic or inorganic.
Warren
2014 Silverado Z71 4x4- 5.3
Flagstaff 21 FRBS
235 nights camping this past 30 months
31000 miles
wnelsonfl is offline   Reply With Quote
Old 07-02-2015, 01:56 PM   #9
Terier's Avatar
I've only have a little build up but I'm going to try your suggestion of toothpaste. I have used toothpaste as putty on walls and to clean brass but didn't know it could clean hard lime scale too. Will also test toothpaste on the taps at home.
Old 07-02-2015, 02:28 PM   #10
wnelsonfl's Avatar
toothpaste is an abrasive and will scratch a plastic toilet
Warren
Flagstaff 21 FRBS
31000 miles
