Old 08-15-2016, 08:18 AM   #21
Wolverine 1945's Avatar
Originally Posted by bruane View Post
Yes judging when the overflow indicates it's full is tricky. I always disconnect the hose and then allow the air to evacuate and then reconnect the hose and generally it fills properly then. Then I check that the indicators are showing full. If that dosent work then the two issues you have need to be fixed or youll never fill the tank!
I have no problem filling our tank,,, I just make sure there is no water in air vent,,, and fill very slowly with a short hose that I made that fits down in the inlet about 2' !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-16-2016, 08:29 PM   #22
You all made me think. I used to fill my tank using the overflow as an indicator of full. I since have decided not to carry 60 gals of water. So , I connected my hose to fill the tank after emptying the tank, placed a bucket under the overflow and then turned on the water to fill and timed this for one minute. One minute of filling with a pressure regulator in line put 5 gals in the tank. Now I will fill to 20 gals for traveling if my destination has hook ups.
palmetto rogue is offline   Reply With Quote
Old 08-17-2016, 09:36 AM   #23
When we first got our rig we would run out of water after maybe a day and a half. I talked to the dealer about the amount of water that would come out of the overflow hose when I filled the tank. He told me some gibberish about how long the fill line was "inside" the RV. What I found out is don't blast the water in under full pressure because it creates a vacuum back pressure that would siphon out half the water I put in. Now it takes me about 15 minutes to fill my 65 gal. tank (w/water heater) at half pressure or less, or the time it takes me to have one beer, which we can stretch to almost a week.
sherman12
2011 Georgetown 330TS
RAV4 on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 08-18-2016, 06:16 AM   #24
When I first read that,,, I thought it said you could stretch one beer out for a week !!! LOL !!! Still working on my 1st cup of Java !!!
I think it probably take me more than 15 minutes to fill our 30 gallon tank,,, Must be added VERY slowly !!! We can only just crack the faucet,,, like a strong trickle !!!
Old 08-24-2016, 07:37 AM   #25
How do I Know My Water tank is Full????
Amazon
P3 P0550 Water Meter $10.75
Fits on end of your hose and will tell you how much you put in. Love it, Love it, Love it works great for me
Camperstewart is offline   Reply With Quote
tank, water, water tank
