Old 07-26-2015, 05:31 PM   #51
Simple method-wad up a couple pieces of newspaper into a ball; make a teepee around it with thin dry sticks of kindling. Light the paper in several places around the "teepee" and when it gets going a little blow gently down low on the flame until the wood catches fire. Now add thicker pieces of wood to it and even build a square frame of logs around it, gradually covering the flames OR just continue to put thicker pieces in the tepee and you should be golden.
royboy334 is offline   Reply With Quote
Old 07-26-2015, 08:08 PM   #52
Stormrider151's Avatar
I'm probably the laziest of all when it comes to fires. 2 box's of Duroflame logs. Stack 3 in the fire ring and light them. Clean burning, last about 3 to 4 hours and there's nothing left of them when done. Told ya......I'm pitiful.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 07-26-2015, 08:22 PM   #53
vinmaker's Avatar
[QUOTE=Maxhise;935741]I cheat big time. Typically I just use a propane torch that was made for asphalt roofing. I do not need paper, twigs, kindling, or even dry wood for that matter. Just stack the logs in Lincoln log fashion and hit em with the torch.
lol. You need to throw some used motor oil on it. That will give a bit more oooph to it.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 07-26-2015, 08:34 PM   #54
trbomax's Avatar
I do hope your kidding about the drain oil?
trbomax is offline   Reply With Quote
Old 07-26-2015, 08:41 PM   #55
tjm
A little kingsford charcoal with a pyramid of wood on top
Sent from my iPad using Tapatalk
tjm is offline   Reply With Quote
Old 07-26-2015, 08:59 PM   #56
mud yapster's Avatar
We use a piece of Pine knot it lights right up and gets a fire going quick. It's free we find it in the wood on our property. It's from old Pine trees that have died and the tree sap concentrate and is very flammable. Just takes a little piece and a spark will almost light it.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 07-26-2015, 10:22 PM   #57
+1, with the match light variety even the crappy wood they sell at the campground will burn.
Frank
Judy, Frank, and Jager
2015 F250 6.7L CC 4x4
2015 Keystone Cougar 30RLi
Zeuster is offline   Reply With Quote
Old 07-27-2015, 08:18 AM   #58
Wolverine 1945's Avatar
Saw some sort of fire starter @ the Gate @ Hartwyck Pines a couple of weeks back,,, looked like some sort of candle ??? They were $1 ???
Wolverine 1945 is online now   Reply With Quote
Old 07-27-2015, 08:22 AM   #59
Flybob's Avatar
Originally Posted by chriscowles View Post
How long (minutes) does one last? I'm thinking in terms of how much hot flame time does it produce, to ignite the other kindling?
Won't start a wet Log, but will ignite reasonably dry sticks. Try one.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-27-2015, 08:52 AM   #60
Glindz233s's Avatar
Go to Home Depot or similar. Get a box of fire muffins (what my son calls them) - which are small pieces of pressed sawdust. Then add larger pieces of wood from finger diameter size up. Light muffin - enjoy!
Glindz233s is offline   Reply With Quote
