Old 03-30-2016, 01:01 PM   #91
JustB_Rad's Avatar
My trucks happy zone seems to be between 65 and 67 MPH....that's where I can get it to occasionally drop down to 8th gear.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 03-30-2016, 04:05 PM   #92
CWSWine's Avatar
Originally Posted by M&K Hoffman View Post
I emailed Maxxis, here is their answer:
Michael,
The Maxxis M8008 ST Radial is "Q" speed rated. However, according to the
Email: MaxxisSupport@maxxis.com | Web: maxxis.com --
They said "Q"Rated so that is only 100 mph not 106. LOL
The local tire rep said the new 17 inch ones were "R" along with the info on Amazon.
http://www.discounttire.com/dtcs/infoSpeedRating.do
Like the email said the ones without the "ST Radial trailer tires, without a service description" (without letter code) are lower speed ratings. If you tire isn't displaying the "Q"(or some other letter speed rating) it is rate to the lower limits. Until mid 2015 ST did not display any speed codes but do to new import rules in mid 2015 they now have speed ratings.
Here is a thread where I ask about the new speed ratings. Speed Rating on ST tires.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-30-2016, 04:17 PM   #93
camper1999's Avatar
60 to 65 since the tires are only rated for 65
2011 GMC 2500HD Diesel
Old 03-30-2016, 06:28 PM   #94
Boondocking Only
ddbck's Avatar
Speed limit here in Wyoming is 80, so thats what I tow at,, 80.
ddbck is offline   Reply With Quote
Old 03-31-2016, 07:37 AM   #95
Too Slow is Dangerous
In graduate school for Transportation Engineering, they taught us that speed differential causes accidents. If everyone on a highway is going almost the same speed, then there are many less accidents. You'll notice semi-trucks are involved in lots of accidents, and also cause accidents. With a 10,000 lb truck, and a 4500 lb trailer, I'm not worried about driving the speed limit. I do get better mileage at 65, but I drive the speed limit on the interstate.
Refuse to buy tires that aren't rated to at least 81mph. eTrailer.com sells Taskmaster tires with that rating. They don't seem to know that, but when you get the tires the rating on the side tells the story. I've read that soon all trailer tires will be rated for 81 mph. About time.
mnoland30 is offline   Reply With Quote
Old 03-31-2016, 08:08 AM   #96
cogito ergo moo
Cowracer's Avatar
Originally Posted by Kaadk View Post
I try to run around 0.0077636 warp. Also known as 0.080781 Mach (at 70F), 53.996 knots, 62.137 Mph or as my truck measures it: 100 km/h.
Wow. That works out to 167023.924 Furlongs per Fortnight!
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 04-01-2016, 11:33 AM   #97
Ready to Go
JeffLynn's Avatar
65 - 70
The Lessmiller's
2001 F250 SD 7.3 Turbo
2013 Sanibel 39' 5th wheel.
JeffLynn is offline   Reply With Quote
Old 04-01-2016, 11:59 AM   #98
Just A Member
EDABEUT's Avatar
I tow at whatever speed the semi's are running in the slow lane. In Michigan if you tow at less than 65 they will be passing you. I will admit that I hate running behind a semi truck so I usually will pass them and just try to stay away. I really hate the 3 or more lane expressways when the semi's are in the 2nd or 3rd lanes passing you.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 04-08-2016, 03:37 PM   #99
Normally 60 to 65--
scrappypappy is offline   Reply With Quote
Old 04-08-2016, 04:22 PM   #100
Depends on the traffic or if the cops are out . Have towed up to 85 . Just got to be confident in your set up and let it roll.
Big Red and 30WR is offline   Reply With Quote
