Old 07-18-2016, 12:40 PM   #1
How level should I be side to side at home?
I currently have our new TT parked out front in our parking area by the curb. I want to move it out back on our concrete pad where I stored my popup. My dilemma is if I ran up on 2x12s I'd need (7) seven high to make it level. I have quite a slope. I'm in the process of finding a permanent solution, but we leave for a week starting 7/25/16 and I want to get it off the road and I have home security out back where I can monitor the TT if it's there.
My question is if I went (3) three high (4 1/2") instead of (7) seven high (10 1/2"). Would it matter if it leaned? It will most likely stay there till 8/10. The day before our maiden voyage.
Thanks everyone
MOD: Could you please change my title to Should "I" be instead of be be
kantonburg is offline   Reply With Quote
Old 07-18-2016, 12:45 PM   #2
PhoneDude 8289's Avatar
I don't think it would matter as long as you are not trying to use the fridge or slides.
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is online now   Reply With Quote
Old 07-18-2016, 12:57 PM   #3
ilmor's Avatar
I agree, plus as long as the roof drains properly, but I don't see where that would be a problem either.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-18-2016, 01:05 PM   #4
No slides on my 26BH and not planning on using the fridge. I'll move it back out front a day or two before to plug the fridge up.
Thanks guys
Old 07-18-2016, 01:13 PM   #5
Herk7769's Avatar
Slides and absorption refrigerators are very "level dependent".
Out of level operation can permanently damage your fridge by slowing or not allowing refrigerant return to the boiler causing overheating and thermal cracking of the boiler.
Out of level operation of the slides can bog (overheat the motor) or damage the gear clutches on your slide out mechanism.
HAM CALLSIGN - KC3FFW
Old 07-18-2016, 01:52 PM   #6
Since I don't have a slide and am not running the fridge I'd be ok correct?
Sent from my SM-G900R7 using Tapatalk
2017 Cherokee Grey Wolf Limited 26BH
Old 07-18-2016, 02:00 PM   #7
Herk7769's Avatar
I would think so. The single possible exception would be in a camper with tandem wheels and front to back out of level (not so much side to side).
On an extreme front to back slope, getting it level (in this case) will shift a lot of camper weight onto the rear axle that would normally be carried on both equally. In this case with long term storage, the rear axle torsion or spring suspension will see more continuous loading even in a rig that is not "overloaded" when parked.
Old 07-18-2016, 04:34 PM   #8
mjones12's Avatar
All I can tell you is that Herk knows his stuff. I'd go by that advice.
2013 Surveyor SP220
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 07-19-2016, 09:12 AM   #9
While you won't damage your fridge if it's turned off while off level, you'll want to level it at least 24 hours before turning it on again to give the ammonia a chance to settle back in where it needs to be.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 07-19-2016, 09:47 AM   #10
Herk7769's Avatar
Excellent tip Tim.
