Old 07-19-2010, 07:40 PM   #1
How Long Are The Chain Suppost To Be?
I order to be effective and do the proper job, how long are the safety chains suppost to be and how should they be attached to the camper?
I have seen chains dragging the ground while camper are in tow.
Old 07-19-2010, 08:47 PM   #2
milzat's Avatar
They should be long enough for you to make the tightest tum with your rig without doing damage to the attaching points. When the tow vehicle and trailer are in a straight line, they should not drag the ground. The chains should be bolted or welded to the trailer frame.
On my last two travel trailers, they were a one piece chain, routed around the back side of the tongue jack and bolted the the frame at two points.
Below is a photo of a welded attaching point.
milzat is offline   Reply With Quote
Old 07-20-2010, 04:06 AM   #3
Thanks for the reply. I thought I would ask because this is a subject that I don't remember seeing on the forum and it's part of the safety feature of the hitch and this is something we all should know and to help the newbies.
