10-16-2015, 08:16 PM
Stufremont
How long will 2 tanks(Rockwood mini lite 2504s)at in 40 degree weather
Doing some winter camping Maryland down to Florida late Nov-early Dec. How long will my 2 propane tanks last if we keep the heat around 65-68? Is it a good idea to get a small electric heater(1500 watts)? We will take our time getting to Florida, with good week to 10 days in the Maryland(5 days), Virginia and Carolina areas.Thanks - this forum rocks!
Stufremont
2020 Ford F-150 3.5L,6 SuperCab
Rockwood 2504S
1 over active Lab-Plays 24/7
10-16-2015, 08:25 PM
Truly hard to say.
To many variables.
Take a spare take?
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
10-16-2015, 08:33 PM
Georgia Rally Coordinator
To many variables to tell how long they will last. Temp is the biggest issue. Yes use a ceramic heater to supplement the propane. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-16-2015, 10:13 PM
We use electric whenever available. This is usually not difficult when we are moving to our final destination and staying at State parks. Refilling propane tanks is not as difficult as one would think. On our recent trip up the East coast we carried only one cylinder and refilled a couple of times over 4 weeks (heating water consumes a good bit of propane).
10-16-2015, 10:27 PM
We have 10 cm of snow coming tomorrow. We are camping next weekend in this. Just use fireplace and furnace. Propane costs $18 for 30 lbs, not really that much. We can run 4-5 days at 32 D F on one 30 lb tank for heat/stove/BBQ/Hot water heater.
B and B
10-16-2015, 10:52 PM
Probably about what B and B said: 4 to 5 days per tank. TT's have better insulation these days it seems. We would run an entire month plus on a single 100 lb bottle in the winter in Colorado, so a 30 lb tank should go 5 days +/- for you.
2015 Palomino SolAire 20RBS
2022 Silverado 2500HD LT Duramax 4WD
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days; 2019: 8 days; 2020: 0; 2021: 10 days.
10-17-2015, 11:52 AM
Do not do the resistant heaters go with ceramic ones.....they put out a lot of heat and are safe you can lay toilet paper on them and it won't catch fire plus they have blowers in them and are quiet and have tip over switches and won't burn a small hand or pet. I was impressed with how much heat you get out of a small cube. Plus you can get them at Walmart/ Lowes/ and Home depot etc.....I hate the smell of a propane heater plus the noise it makes....
10-17-2015, 12:31 PM
How long will two tanks last?
First of all, do you have 20 lb or 30 lb tanks. We winter camp up here on Vancouver Island. If you are going propane alone you will go through a 20 lb tank pretty damn fast. Far and away the best option is buying a small electric heater. If you do not have power and are running your furnace you will be lucky to make through the first nite. We purchased a Dimplex fireplace. It is the Cat's Pyjamas. Very low electric draw, gives a very nice simulated flame to watch in your cozy trailer and throws medium and high heat. Look for a stove shop that sells dimplex in your area. They have a very good rep for lasting long and workmanship.
10-17-2015, 12:42 PM
We just returned from 8 days in the mountains with over night temps in the low 30 and daytime around 45-50
Went thru a 20 pound in 5 days and that was with a ceramic heater as well but then DW likes it very warm.
10-17-2015, 01:53 PM
Actually do it the other way around. If you have electric heat use it and set the furnace around say 60 to 65 degrees. Why heat with propane if you are already paying for electric? I am using this one and am quite pleased with it so far.
http://www.amazon.com/gp/product/B000GLHVZA?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s00
It has a thermostat and on auto runs till it reaches the set point, then the fan goes to low and keeps the air circulating. When it cools down a little the heat comes back on and the fan goes to high again. It is small so sits on my kitchen counter and is quiet. It is windy and 51 degrees out and is keeping my trailer at 72 right now with no problem at all.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
10-17-2015, 04:48 PM
I always use an electric heater in addition to the electric fireplace. I bought a NOCO GCP1 120V power inlet and installed it in the side of the end of the slide near the 30A inlet just for the extra heater. The furnace is set to come on only if the electric heaters can't keep up (and it did a few times last week where I was camping with only 15A outlets and it went into the mid 30's overnight).
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
10-17-2015, 05:04 PM
Last year I found (2) Vornado Vortex heaters on clearance at BB&B. They have a 750W setting so that I can run (1) near the master & (1) near the kids' bunk area without overloading a circuit. They have thermostats & tip-over protection and run VERY quiet. The fan blade technology pushes more air than cheapo units without being so noisy...
When heating with electric I set the TT's propane heater to 60, just in-case electric fails at night. I also leave the TT's fan on so that warm air circulates through the vents. This has kept our water lines from freezing when the nights dip into freezing temps...
2011 RAM 2500 ST Crew Cab 5.7 Hemi
2011 Primetime 3150BHD Touring Edition
Days camped in 2018- 25
2017- 31; 2016- 36; 2015- 37; 2014- 31
10-17-2015, 05:58 PM
Maron
Depends
Fireplace and electric blankets help a bunch. But size of the tanks is a major factor as well. Our 35' has tanks that hold 7 lbs of pp. in cooler weather (30-55') a tank lasts a week or more. I leave 1 tank off & switch when the other is empty. That is usually about
3 am.
Campers World near us has a 20% discount on Tuesday & Wednesday with a Good Sam card. That works out to $13 to $16 per tank.
10-17-2015, 06:29 PM
Yikes that a bunch of money for a refill compared to my $8 per 20 # bottle. Later RJD
Days camped 2019 62
10-17-2015, 06:32 PM
Get a ceramic heater and use it. Use the electric your paying for and save $$ on propane your not using.
10-18-2015, 10:08 AM
Retired
great forum...this is our first fall camping experience with our WJ and early morning temps last week were low 40s high 30s.
aceinspp: I'm moving to GA.... $18 /20# & $27/30# and we carry 2 30# tanks in our WJ.
stufremont: I agree with the idea if you are paying for elec use it. We have a 1500W ceramic heater we use in the evening (living rm area) and early morning (bath rm and bedrm area). We shut the hallway doors to the bathrm & bedrm and use the elec heater in the mornings...nice to get dress when its warm. We set the furnace to 62 for the overnight to keep the chill off in the TT. One thing we did notice with the elec heater is we couldn't fire-up the elec coffee maker at the same time. We decided COFFEE first....
Happy Trails
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
10-18-2015, 10:44 AM
Aceinspp, I haven't seen propane anywhere in the country for under two bucks a gallon in a long time. $18 for a 30 lb tank is a great price.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
10-18-2015, 10:59 AM
I would feel like I was getting ripped of if I paid $18.00 to fill a 30 lb tank. Here, in Amish country, at the Amish hardware store, I pay 30 cents a pound. That equals $9.00 to fill a completely empty 30 lb tank.
Bruce
10-21-2015, 10:48 AM
Attachment 92023
Happy Trails
Coffee is always first! Warm my inside before my outside,
Jim
George Bernard Shaw
