Old 10-16-2015, 08:16 PM   #1
Stufremont
Stufremont's Avatar
How long will 2 tanks(Rockwood mini lite 2504s)at in 40 degree weather
Doing some winter camping Maryland down to Florida late Nov-early Dec. How long will my 2 propane tanks last if we keep the heat around 65-68? Is it a good idea to get a small electric heater(1500 watts)? We will take our time getting to Florida, with good week to 10 days in the Maryland(5 days), Virginia and Carolina areas.Thanks - this forum rocks!
Stufremont
2012 Ram 1500
Rockwood 2504S
1 over active Lab-Lets play fetch!
Stufremont is offline   Reply With Quote
Old 10-16-2015, 08:25 PM   #2
TURBS's Avatar
Truly hard to say.
To many variables.
Take a spare take?
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
Old 10-16-2015, 08:33 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
To many variables to tell how long they will last. Temp is the biggest issue. Yes use a ceramic heater to supplement the propane. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 10-16-2015, 10:13 PM   #4
We use electric whenever available. This is usually not difficult when we are moving to our final destination and staying at State parks. Refilling propane tanks is not as difficult as one would think. On our recent trip up the East coast we carried only one cylinder and refilled a couple of times over 4 weeks (heating water consumes a good bit of propane).
pjnlorrie is offline   Reply With Quote
Old 10-16-2015, 10:27 PM   #5
B and B's Avatar
We have 10 cm of snow coming tomorrow. We are camping next weekend in this. Just use fireplace and furnace. Propane costs $18 for 30 lbs, not really that much. We can run 4-5 days at 32 D F on one 30 lb tank for heat/stove/BBQ/Hot water heater.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-16-2015, 10:52 PM   #6
Probably about what B and B said: 4 to 5 days per tank. TT's have better insulation these days it seems. We would run an entire month plus on a single 100 lb bottle in the winter in Colorado, so a 30 lb tank should go 5 days +/- for you.
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 20 days (so far)
elchilero53 is online now   Reply With Quote
Old 10-17-2015, 11:52 AM   #7
Do not do the resistant heaters go with ceramic ones.....they put out a lot of heat and are safe you can lay toilet paper on them and it won't catch fire plus they have blowers in them and are quiet and have tip over switches and won't burn a small hand or pet. I was impressed with how much heat you get out of a small cube. Plus you can get them at Walmart/ Lowes/ and Home depot etc.....I hate the smell of a propane heater plus the noise it makes....
Bob Vaughn is offline   Reply With Quote
Old 10-17-2015, 12:31 PM   #8
How long will two tanks last?
First of all, do you have 20 lb or 30 lb tanks. We winter camp up here on Vancouver Island. If you are going propane alone you will go through a 20 lb tank pretty damn fast. Far and away the best option is buying a small electric heater. If you do not have power and are running your furnace you will be lucky to make through the first nite. We purchased a Dimplex fireplace. It is the Cat's Pyjamas. Very low electric draw, gives a very nice simulated flame to watch in your cozy trailer and throws medium and high heat. Look for a stove shop that sells dimplex in your area. They have a very good rep for lasting long and workmanship.
flugelboneman is offline   Reply With Quote
Old 10-17-2015, 12:42 PM   #9
Dabmeb's Avatar
We just returned from 8 days in the mountains with over night temps in the low 30 and daytime around 45-50
Went thru a 20 pound in 5 days and that was with a ceramic heater as well but then DW likes it very warm.
Dabmeb is offline   Reply With Quote
Old 10-17-2015, 01:53 PM   #10
Actually do it the other way around. If you have electric heat use it and set the furnace around say 60 to 65 degrees. Why heat with propane if you are already paying for electric? I am using this one and am quite pleased with it so far.
http://www.amazon.com/gp/product/B000GLHVZA?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s00
It has a thermostat and on auto runs till it reaches the set point, then the fan goes to low and keeps the air circulating. When it cools down a little the heat comes back on and the fan goes to high again. It is small so sits on my kitchen counter and is quiet. It is windy and 51 degrees out and is keeping my trailer at 72 right now with no problem at all.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
rockwood, tank
