03-05-2017, 12:35 PM
How long will my battery last on running fridge on propane?
Friday I will taking my 5ver to a location that doesn't have power. I will have a generator that I will run I'm while there. I will be leaving the place for 4 days and want to know if my battery (I only have one) will last running only my propane Frdge while I am gone or do I need to take my food with me when I leave? Temps will be around 80 during the day and upper 50's at night. I have one of those Dometic four door model refrigerators.
TIA
Rick
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
03-05-2017, 12:51 PM
It depends on a lot. How old is the battery?
2019.5 Rockwood 2509S
03-05-2017, 12:55 PM
Around 3 years old. It will actually only be around 3 days. I am leaving in the afternoon on one day and returning 3 days later in the morning.
2021 Alpine 3790FK
03-05-2017, 01:04 PM
I doubt it will last 3 days, as other stuff draws on it also
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
03-05-2017, 01:24 PM
a furnace alone will empty the battery in one night.
but the fridge will use very little battery power.
but it depends on how many parasitic power drains your RV has.
03-06-2017, 06:20 AM
Thanks for the replies. I think I am gonna roll the dice and see what happens.
2021 Alpine 3790FK
03-06-2017, 06:57 AM
TIA
Rick
Your 4 door refer is located in a slide,this location Sometimes requires the Install of Fan/Fans for proper cooling! Some fans are installed by Factory some by owners! If your unit has these cooling fans they will also use 12V power,your gamble could end up with a Very Bad Smelly outcome! Youroo!!
03-06-2017, 07:30 AM
Do a dry run at home if you can, then you will know before leaving. Put a few bottles of water in fridge and freezer.....
Fonzie
03-06-2017, 07:56 AM
Turn off everything else but the fridge!
Pull fuses if you have to....
3 days should not be a problem.
My 2¢
Peace!
Dan & Rita D
03-06-2017, 07:59 AM
My 2¢
Agreed.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
03-06-2017, 02:32 PM
Roll your dice if you will, but a trailer that big ought to have no fewer than two good batteries. IMHO
03-06-2017, 02:53 PM
Originally Posted by jtstromsburg
Agreed.
agreed times 3. turn everything off except fridge.
03-06-2017, 03:51 PM
padcarroll
When in doubt we save commercial gel packs used for shipping perishable food and keep some in the freezer. We move some of them into the refrigerator when leaving unit for several days. The bags usually last 2 days without refrigeration.
Dave and Pam Carroll
Callie - 9 yo chihuahua/yorky mix
2014 Legacy SR300 340BH
2013 Chevy Sonic Toad
Full-timing since January 2016
03-06-2017, 04:44 PM
I am not sure but our batteries went down fast with just the frig on until we turn the switch on the frig to gas only instead of auto. Seemed to make a world of difference! I think something keep searching for 110 and used up the battery?
03-06-2017, 07:02 PM
Most fridges have a 12v heating element that keeps condensation from forming at the doors. This is the biggest draw on the 12v system by the fridge. I disconnected the wire to this heater on my Domestic fridge to extend my battery life. (It also disconnected the light in my fridge.)
The fan on the heater is also a big load on the battery. One of those portable propane heaters works well to heat the trailer, but leave a window cracked for ventilation.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
03-07-2017, 07:00 AM
MCTroy
Add plenty of ice in the freezer and frig. Our smaller frig stayed cold for 4 days on propane. We had to pull out to avoid a flood. No time to take anything out but I always keep ice in the freezer and I think that saved the day, or at least the frozen hot dogs!
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
