Old 07-06-2015, 11:37 PM   #1
RV Vagabond Jerry
Jerry Dixon's Avatar
How many AMP's does each item use
Does anyone have a list of each piece of electrical equipment in a motorhome showing how may AMP's they take? I need to pre-plan which items I can use at the same time without blowing a fuse.
Jerry Dixon is offline   Reply With Quote
Old 07-07-2015, 04:16 AM   #2
fonzie's Avatar
normal appliance amp draws
Fonzie
Old 07-08-2015, 11:39 PM   #3
Just be aware that on start up any motor will pull more than the chart indicates, it's brief but real and will affect what your inverter or generator or what a supply circuit can handle. A/C units are the worst about this.
If you are restricted by your power feed also keep in mind that you cannot continuously draw what the circuit is rated at or it may overheat. For example you might be able to run an a/c on a 20 amp circuit along with the parasitic draws in your trailer but you will be maxing that circuit out and running a fire risk.
I know this because I had a burned up GFI outlet demonstrate this first hand. Circuit, outlet and breaker all rated at 20 amp.
Brentf is offline   Reply With Quote
Old 07-09-2015, 12:41 AM   #4
SYE
SYE's Avatar
Wattage % Volts = Amps
Amps X Volts = Wattage
One other thing to keep in mind is many RV appliances require more amps to start the appliance than they do to run the appliance. A roof air conditioner can draw 16 amps to start, but may only use 13 amps once it is running.
120 Volt AC Amp Ratings
Appliance or Electronic Equipment Estimated Amps
Air Conditioner (X number of A/C) 12-16 Amps
Blender 5-6 Amps
Coffee Maker 5-8 Amps
Compact Disc Player 1 Amp
Computer (Laptop) 2-3 Amps
Converter 1-8 Amps
Crock Pot 1-2 Amps
Curling Iron <1 Amp
Drill 2-6 Amps
Electric Blanket 0.5-1.5 Amps
Electric Fan 1 Amp
Electric Water Heater 9-13 Amps
Electric Skillet 6-12 Amps
Hair Dryer 5-12 Amps
Iron 5-10 Amps
Light (60 watt % 120V) <1 Amp
Microwave 8-13 Amps
Microwave (Convection Oven) 13 Amps
Refrigerator in AC mode 5-8 Amps
Space Heater 8-13 Amps
Television 1.5-4 Amps
Toaster 7-10 Amps
Vacuum (handheld) 2-6 Amps
VCR 1-2 Amps
Washer/Dryer 14-16Amps
12 Volt DC Amp Ratings
Appliance or Accessory Estimated Amps
Aisle Light 1 Amp
CO Detector 1 Amp
Fluorescent Light 1-2 Amps
Furnace 10-12 Amps
LP Gas Leak Detector 0.5 Amp
Overhead lights (Per Bulb) 1 Amp
Porch Light 1 Amp
Power Roof Vent 1.5 Amps
Radio/Stereo 4 Amps
Range Hood (Fan & Light) 2-3 Amps
Refrigerator (LP Gas Mode) 1.5- 2 Amps
Security System 1 Amp
Television (12 volt) 4-5 Amps
TV Antenna Booster <1 Amp
TV Antenna Booster 12 Volt outlet Up to 8 Amps
Variable Speed Ceiling / Vent Fan 4 Amps
VCR Recorder / Player 2 Amps
Water Pump 4 Amp
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
