Old 03-07-2016, 10:21 PM   #1
rvpirate's Avatar
How much 5th Wheel?
Have a 2013 Wildwood XLITE 261BHLXL, but we're ready to upgrade to a nicer 5th wheel. Currently tow with a 2003 F250 (7.3L) Crew Cab LWB 4x4. Have noticed some of the 5th Wheels exceed 40ft. Feel I wouldn't have any problems pulling any, but figure the LWB 4X4 limits my hitch weight. Where should I set my expectations at for 5th wheel size? Any info is greatly appreciated!
2003 F250 Crew Cab 4x4
2016 Nights camped: 6
rvpirate is offline   Reply With Quote
Old 03-07-2016, 11:33 PM   #2
SKnight's Avatar
Depends on what you want. I wanted less than 40 feet long so I can still go to all the places I want to go, I haunt state and national parks which usually have a 40 foot limit, the exceptions are usually 35 foot limits but my model number is 346, so they usually say c'mon in and it's been no issue.
I wanted to net out under 13,000lbs, I knew from experience that I carry 750ish lbs of stuff minus water. My yellow sticker says 11,336lbs dry. So that's 12,350ish pounds water and all. My GVWR is 15,550. I don't know where I'd put 4,214lbs of stuff.
I'm over on payload by 320lbs. Sue me, I'm so far under my axle ratings it's a joke.
So, know what your truck can do, decide what you want to achieve and see if you can put it under the same umbrella. Consider your favorite places and length restrictions, where you want to go and their restrictions. Odds are you're going to end up mid to upper 30's and pushing 13-14,000 going down the road.
Old 03-08-2016, 12:18 AM   #3
asquared's Avatar
That depends on your truck ratings. You can look at the tire loading sticker for your payload before occupants, pets, gear etc. to get a rough idea.
Best thing to do is go weigh your truck at a local truck scale. Weigh it fully loaded with all occupants, pets and gear that would be in it when towing plus a full tank of fuel. Get separate front and rear axle weights. Take the rear GAWR and subtract the scaled rear axle weight. Your hitch plus loaded pin weight need to be less than this number. Take the truck gcwr and subtract the total scaled truck weight to get your adjusted towing capacity. Your loaded trailer weight needs to be less than this number. Take the truck gvwr and subtract the total scaled truck weight to get your available payload. Your pin weight plus hitch needs to be less than this.
Now remember advertised dry weights are not what you will tow. You want to think about loaded trailer weights. You have the advantage of having a tt already. When you weigh your truck, bring your tt. Get a second weight with the tt hooked to the truck. The total difference between the two tickets will give you the tt weight. If you subtract the weight from the tt yellow sticker dry weight (usually found in the door frame or inside a cabinet) you will know how much "stuff" you load in a trailer. You can now add that number to any fiver's dry weight to get a rough estimate of where your loaded weight will actually be. Loaded pin weight should be 20-25% of loaded fiver weight (mine is 21% per scales). Calculating these things will give you an idea of what weight fiver to look at. Be advised you might add more into the extra storage of a fiver so I wouldn't get to close to limits based on these calculations allow yourself some wiggle room.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-08-2016, 08:33 AM   #4
cogito ergo moo
Cowracer's Avatar
2003 f250 7.3 auto trans with 3.73 gears tows a max 5ver of 12,800 (taken from the official Ford Towing Guide)
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
Old 03-08-2016, 08:39 AM   #5
AquaMan's Avatar
Thanks Cowracer, I was about to point out that the 7.3 is about half of the HP and Torque of a current model diesel. Very capable, but not near the level of a current model.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 03-08-2016, 10:15 AM   #6
But it will out live any 6.0 or 6.4.....
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 03-08-2016, 11:56 AM   #7
Telstar's Avatar
Our Cardinal model is 33TS-LX, it's 36.5' overall. The GVWR is 14,400 loaded scale weight is 12,800. Scale hitch weight is 2,828 (22%). We pull it with a 2005 F-350 crew cab and the match seems to be right. I would pull this rig with a F-250 as the 350 has a higher load capacity.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 03-08-2016, 12:01 PM   #8
We had a 35' jayco 5th wheel for 5 years.. looking to retire so we just upgraded to 42' Heritage Glen f368rblk .. we are Glampers as well.. spent 20 year on the ground in a tent.. now want all the conveniences
Jeff from Burlington Ont is offline   Reply With Quote
Old 03-08-2016, 12:55 PM   #9
We have a 32' Rockwood Signature Ultra-lite 8282ws. Dry weight is 7900 lbs, pin is 1180 lbs and full is 9200 lbs. It has a slide with 2 lazy boys, a rear full length couch and a slide that incorporates a computer table, pop up tv, fireplace, fridge, stove and counter. Have another large counter with double sinks. Bathroom is standard with sink, toilet, shower and linen closet. Bedroom has a residential queen bed (60"X80"). Everything we want and need. Others may want larger and some smaller. Everyone to their own. Happy hunting.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 03-08-2016, 01:09 PM   #10
I have a 36RLTS. If I had to do again I would choose 30-32 foot. 36 is more difficult to maneuver and heavier.
Harkerr is offline   Reply With Quote
5th wheel, wheel
