Old 05-20-2016, 10:33 AM   #1
Shawn.O's Avatar
How Much Movement should I feel?
We recently purchased our Grey Wolf 23DBH and I've noticed a lot of movement after we've setup camp when we're inside the camper. For instance when we're all in bed, if my son (16yr/120lbs) moves or rolls over in the back top rack I can feel the camper shake from the front queen bed. is this normal or should I be cranking down the stabilizer jacks a bit more?
thanks,
Shawn
Chief, U.S. Coast Guard Reserve
2016 Grey Wolf 23DBH
2007 F-150 5.4 Triton V8
Shawn.O is offline   Reply With Quote
Old 05-20-2016, 10:39 AM   #2
BandJCarm's Avatar
Get some scissor jacks. I had 26dbh, had same issue, put scissor jacks around in strategic locations, pretty much solved the problem. The jacks that come with it won't stabilize it. Do NOT crank them down too much, they are not made to lift the trailer weight.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-20-2016, 10:42 AM   #3
fields's Avatar
Our last travel trailer used to do that. They make a universal stabilizer you can get from camping world that will help.
2009 Georgetown M-350TS
fields is offline   Reply With Quote
Old 05-20-2016, 10:53 AM   #4
BandJCarm's Avatar
By the way...on my post.......do not put the scissor jacks under the slideout (do you have a slideout? Not sure........). Stabilize THEN open slides.
FROG AR-0019-242
Old 05-20-2016, 11:07 AM   #5
TURBS's Avatar
Jt strongarms!
Worth the investment!
Can use on front and rear on travel trailer or 5th wheel!
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-20-2016, 11:45 AM   #6
Stormrider151's Avatar
Completely normal. After all it is vehicle on springs. I use x-chocks and blocks under the lowest entry step. No issues. Others have pla ced scissor jacks in front of the wheels and the strong arms. What you don't want to do is place jacks under any slides you may have.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-20-2016, 12:05 PM   #7
Hold Wheels Firmly
The scissor wheel chocks on both sets of wheels helped me a lot when I experienced this.
I guess it provided a sturdier platform.
jw
And am in a 2014 Grey Wolf
kewlestguy is offline   Reply With Quote
Old 05-20-2016, 12:28 PM   #8
2015 Silverback/2014 F250
On the scissors wheel jacks how much pressure can you put on them, will it hurt the wheel spring system?
chisumbella is offline   Reply With Quote
Old 05-20-2016, 12:42 PM   #9
Unable to quantify in newton meters or anything.
The assembly is pretty tough to carry around a few tons. So I wouldn't be overly concerned with stressing it.
Make it snug and feel the difference.
If you were to pull the RV the wheels should drag and not turn while the chock is on it.
And you asked about scissor jacks.
I answered for the scissor chocks... :-/
Old 05-20-2016, 12:45 PM   #10
Originally Posted by TURBS View Post
Jt strongarms!
2008 2500hd Duramax
2015 Columbus 320RS
Had these on my last rig. They really work!
My current rig has 6 point Lippert leveling system . Works great to level, but does not keep the unit as stable as JR Strongarms. There is a debate as to wether or not the Strongarms are compatible with the Lippert system, so I keep wishing for them.
2014 Coachmen Brookstone 325RL
2015 Chev Silverado 2500 Diesel.
ottawapaul is offline   Reply With Quote
