Old 08-05-2015, 08:36 PM   #1
RV Vagabond Jerry
Jerry Dixon's Avatar
Question How much power is needed for satellite tv
I am thinking about getting satellite tv for a motorhome. With only 15 amps while boondocking, it that enough to power the satellite system, tv, lights, etc?
Jerry Dixon is offline   Reply With Quote
Old 08-05-2015, 08:56 PM   #2
Who Dares, Wins
doc73's Avatar
I run our whole trailer, minus ac on an eu2000. This includes TV, DVr, and tailgator
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 08-06-2015, 07:12 PM   #3
RV Vagabond Jerry
Sure with the generator on, no problem, but I mean using only batteries
Old 08-06-2015, 08:09 PM   #4
rugersdad's Avatar
I use a 600 watt Xantrex pure sine wave inverter and have six golf cart batteries and run a 42 inch HD TV, dish 211 reciever and a pathway x2 portable sat dish. I only have 220 watts of solar and it holds its own during full sun. At night I run the onboard around fifteen minutes every seventy five minutes to keep the batteries topped off. The six batteries and 600 watt inverter are overkill for those power demands. I started with a 400 watt inverter and four golf cart batteries. You can do it as long as you don't have a big TV and you keep an eye on your batteries state of charge.
rugersdad is offline   Reply With Quote
Old 08-06-2015, 11:10 PM   #5
RV Vagabond Jerry
Rugersdad, how many amps are you getting without the generator running?
Old 08-06-2015, 11:22 PM   #6
Batts-toy's Avatar
Please explain a little more about the 15 amp source you are going to use.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 08-07-2015, 11:32 AM   #7
RV Vagabond Jerry
I am talking about the entire unit powered only by the batteries, which are recharged each day by solar.
Old 08-07-2015, 11:52 AM   #8
The length of time you can run the sat/DVR/TV system is going to depend on the total amp hours your system will deliver and the total amps the set up plus your other devices draw.
Middleburg Redneck is offline   Reply With Quote
Old 08-07-2015, 12:00 PM   #9
Batts-toy's Avatar
Correct me if I am wrong, I'll assume the tv and satellite system are 110 volt AC which will be fed by an inverter that gets 12 volt DC power and changes it to 110 volt AC for that purpose - 15 amp AC. The TT lights (12 volt DC), fridge and furnace on propane with 12 volt DC for the related control circuits. If this is your setup then you will be just fine provided your battery bank and solar setup keeps up with your usage.
Old 08-07-2015, 08:22 PM   #10
rugersdad's Avatar
Jerry I believe I am getting around 15 amps to the battery bank from the solar in full sun.
power, satellite
