Old 03-23-2014, 07:01 PM   #1
Charles Firth's Avatar
How much pressure ?
When I took delivery of my Windjammer,one of the freebees they gave me was a pressure regulator for the TT. My question is, are they all preset to 45 psi ? That does not seem like a lot of pressure or is that all the pvc plumbing can handle ? I think city water usually is about 60psi. I would guess the water pressure could be considerable less if the camp ground is crowded and lots of water usage. Is water pressure a common problem at CG ?. Lots of experience out there, how do you all handle it ? Thanks in advance
Chuck in Va
3065w Windjammer
2001 F250 gas
Charles Firth is offline   Reply With Quote
Old 03-24-2014, 09:24 AM   #2
Fulltime family RVer
I think a common target is 45-50 psi.
I'm unsure how often pressure is high at campgrounds- it's one of those things, "everyone says you should have one", so I have one. In fact, after suffering the cheap $8 fitting, I sprung for a $80 nice Watts regulator and have been showering my luxurious mane in bliss.
ependydad is online now   Reply With Quote
Old 03-24-2014, 09:28 AM   #3
Send a message via MSN to Tiggerdad
If it's the non-adjustable male x female straight connection regulator, throw it away and buy a Watts or do without.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
pressure
