Old 01-29-2014, 11:18 PM   #1
NurseJohn's Avatar
How to hook up RV PARK Cable to my 2013 CoachmenFreelander
1. ok I connected the coax cable from the lot post to the cable connection located beside my water sources
2. I connected my Jensen TV to the Comcast cable box that the park gave me
3. I connected the cable box to the antenna/cable/12v power source located in the bunk space above the cab
4.I switched my tv source from air to cable
5. I called Comcast and they sent a signal that "activated" the box
6. on screen it searched for cable network, did the 100% scan
7. no channels
8. 8 hours later and 3 calls to Comcast I still have no channels.....sigh
1. what am I doing wrong?
2. should the power button on the antenna wall plate be on or off
any help would be appreciated.
NurseJohn is offline   Reply With Quote
Old 01-30-2014, 12:03 AM   #2
iceblaze580's Avatar
The button on the wall plate needs to be off
iceblaze580 is offline   Reply With Quote
Old 01-30-2014, 03:48 AM   #3
NurseJohn's Avatar
hi iceblaze.... why does the button need to be off.....can you step me through the reasoning?
thx
Old 01-30-2014, 05:19 AM   #4
TTNewbees's Avatar
It's a booster for over the air station and you are using a direct connection thru coaxial cable
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 01-30-2014, 05:32 AM   #5
themounties's Avatar
If they gave you a remote make sure the cable button on the remote is highlighted hit the power button and within a couple seconds hit the ok button might have to push it a couple times that should bring up a diagnostic screen arrow down to #3 and than right arrow see if it has carrier lock if it doesn't say yes it's probably the inside wiring if that's the case try running it from the post to the back of the comcast box and do the diagnostic thing again that'll tell you if it's inside or outside
themounties is offline   Reply With Quote
Old 01-30-2014, 05:34 AM   #6
NurseJohn's Avatar
Thankyou Mounties, I'll give that diagnostic plan a try....
Old 01-30-2014, 05:44 AM   #7
I meant to ask is it HD box or regular cable box?
Old 01-30-2014, 05:44 AM   #8
NurseJohn's Avatar
regular
Old 01-30-2014, 06:00 AM   #9
You said you tried the search you shouldn't have to do that just make sure tv is on 3 or also it's not one of the real small box is it I know there different everywhere
Old 01-30-2014, 07:51 AM   #10
NurseJohn's Avatar
Name:	ImageUploadedByForest River Forums1391089458.642370.jpg
Name:	ImageUploadedByForest River Forums1391089491.764554.jpg
Name:	ImageUploadedByForest River Forums1391089650.929560.jpg
the image that I get on the screen appears when the box is connected to the tv but it appears even IF the box is not connected to the cable plate above the bunk which tells me there is communication between the box and the tv.
the image of the box shows a green light but the light is actually blinking
2013, coachmen
