Old 09-03-2013, 02:41 PM   #1
schrek's Avatar
How to keep flies out of my camper?
I was wondering if anyone has had a fly problem in their camper and how it was solved? The last 2 weekends we have been out camping and have had an excessive amount(50-60 at one time) of flies in our camper. The door is shut all the time and there is no rips in the screens either. I know that we are going to have some flies it's camping but the amount is unbearable! Any ideas would be helpful.
schrek is offline   Reply With Quote
Old 09-03-2013, 02:52 PM   #2
Graduate Member
RoadTrip's Avatar
We don't get that many - but one solution i'm looking into is getting a venus fly trap.
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 09-03-2013, 03:13 PM   #3
Crusader's Avatar
It maybe possible that you have a small dead animal in the trailer or in the under belly. Sometimes it will attract the fries and not smell.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 09-03-2013, 03:31 PM   #4
Truth B Towed's Avatar
I have no problem either to that extent, just acouple that might sneak in when going in or out.
2008 Silverado 5.3 tow package
2013 Roo 25rs
2014 nites booked 10
Truth B Towed is offline   Reply With Quote
Old 09-03-2013, 03:46 PM   #5
Terier's Avatar
You mentioned that the door is closed but do you use the screen door? On my TT I noticed a gap wide enough for flies to come in even with the slider closed. There's a slight bend with with my slider door so it doesn't fit snug. A strip of form rubber was added which seems to be doing the trick.
Terier is online now   Reply With Quote
Old 09-03-2013, 04:04 PM   #6
NELA
Weezer's Avatar
OK, here's a tried and true method I've used at home, and even around horse stables;
Take a quart sized zip lock back, fill it with water, and hang it near the door.
Evidently this water causes vision refraction due to their complex eyes;
HowStuffWorks "Can a bag of water keep flies away?"
Usually the zip lock is hung by tacks thru the area above the zipper. For your RV I'd use the clothes hangers designed to hang trousers, clamping the plastic above the zipper between the tension bars. Then hang the bag by the hook on the awning arms, etc.
I've tried this. I works. I don't swear by *how* it works, it just does.
I've never put the flakes of tinfoil inside the water, or the penny. Just plain clear water in a ziplock bag.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 09-03-2013, 04:05 PM   #7
NELA
Weezer's Avatar
P.S. Once inside I'd use the sticky fly strips.
Old 09-03-2013, 04:59 PM   #8
2013leprechaun319dsf's Avatar
I've heard that pennies inside a ziplock bag filled with water work well. Light reflection confusing the little buggers.
2013leprechaun319dsf is offline   Reply With Quote
Old 09-03-2013, 05:22 PM   #9
phat phrog stunt crew
what about the zip lock baggie thing and a couple magnets .. 1 inside screen door, and the other outside on or in the ziplock bag? should hold it fairly snug.
dwaynerz is offline   Reply With Quote
Old 09-03-2013, 05:44 PM   #10
Denver, CO
garbonz's Avatar
Gun them down with Bug A Salt... A little salt won't hurt nothing and it drops them right in their tracks. Kinda fun to. Doesn't work so well on wasps, tho; it just pisses them off. Don't ask me how I know.
BUG-A-SALT: The Original Salt Gun
2017 Fuse 23T
