Old 02-11-2016, 12:23 PM   #11
We use cotton balls soaked in peppermint oil and keep an old radio in the RV playing 24/7. The noise and oil have worked perfectly for 3 yrs. (I ran an extension cord from house to RV for the radio.)
billcoll is offline   Reply With Quote
Old 02-11-2016, 12:35 PM   #12
Rats and Squirrels
We have a fairly new Georgetown and it must be tight since I have not had a rat or squirrel problem inside. However, we had something, I think squirrels in cold weather, build a nest in the V of the engine and chew on the wires. I keep open containers of D-Con on the engine and in the frame and seemed to have stopped the problem although they sometimes empty the containers.
hikerjohn7 is offline   Reply With Quote
Old 02-11-2016, 12:40 PM   #13
Flybob's Avatar
PLEASE do not use Rat Poison. It works by causing the rodents to bleed to death internally. It is not immediate and in the process of dying they become very thirsty and go out in search of water. While outside and dying they are easy prey for hawks and owls. If eaten by a bird of prey, they will also poison them. Keep rodents out with peppermint or cab fresh or trap those that get in with snap traps.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-11-2016, 12:47 PM   #14
Justice12t's Avatar
Originally Posted by Josey View Post
Mothballs have worked for us. Put them in the outside compartments and under the trailer. Get a little of the mothball smell when you reopen for spring but it doesn't last long.
Purchased a pop up when I first started camping for cheap. Was told that it had been sitting for awhile and just need a good cleaning and the fabrics washed. Come to find out the previous owner loaded it with mothballs and left them in there for I am guessing years...needless to say I never got the smell out...No mice though! but make sure they are used outside only...
We currently use Irish Spring and dryer sheets...we are parked on a gravel pad next to the garage.
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 02-11-2016, 01:02 PM   #15
Rat Poisen
I had lots of trepidation about using rat poisoning but I was getting desperate since the varmints chewed wires on top of the engine costing over $700 to replace a damaged wire harness. They also chewed holes in my $350 Adco RV cover. I tried everything else I could find but it did not work. My wife was panicking and I was facing having to sell the RV. The D-Con seems to be working however. That said, I never place it outside on the ground. I place it only on the top of the engine and at a point in the frame near my propane tank. The only animals affected are ones which invade my RV. Until someone comes up with a better deterrent for rats and squirrels, I will have to stay with the D-Con.
Old 02-11-2016, 02:06 PM   #16
Mothballs, but frankly, Decon is the way to go. I put it near each contact point on the ground: Tires, jacks, and power/water lines.
I don't want mice in the cabin, they carry fleas, which carry plague (it is endemic in the south west) and Hanta Virus in their urine. Since they pee everywhere they go, so they can mark their trails, that is a lot of exposure to very serious disease.
I don't use traps, since I don't want to be handling them.
hankpac is offline   Reply With Quote
Old 02-11-2016, 02:33 PM   #17
shughey00's Avatar
no matter what we used as a deterrent mice loved our 5ver, Dryer sheets...Fresh cab...Irish Spring...they did not care.
Put mouse traps in to catch them I put one trap on top of a dryer sheet and one next to a fresh cab pack...caught mice in both. The mouse had to crawl across the dryer sheet to get to the trap on top...and the fresh cab pack was right next to the other trap.
Mice could care less...caught em in both. As well as a 3 other mice in other areas.
So I don't care what people say about the deterrents...my mice don't care what you use. Accept if its a trap or poison. SO no more moth balls...dryer sheets...fresh cab...I call BS.
If you dont want them then you have to find every stinking little access point...plug those up.... and still use some sort of trap or poison....cause around here...they just laugh at the home brew crap. Even the famed Fresh Cab didnt work...they even built a nest in a cabinet with a new fresh cab packet....no food in there...just a few pots and a roll of paper towels which they tore up for a nest,
shughey00 is offline   Reply With Quote
Old 02-11-2016, 06:10 PM   #18
OscarsMom2's Avatar
As stated previously be sure to plug all of the holes you can find. We use steel wool in places where electric lines enter the RV. We usually use a product called Shake Away for years and it really worked. Mouse Repellent - Rodent Repellent Granules I always ordered from the company, but I see that you can order from Amazon. Our local Ace Hardware has it, too. This year, I used Cab Fresh. It has quite a potent smell and gave me a headache whenever I went it the RV, so I took it out and have gone back to Shake Away. We put trays of it in the RV and sprinkle it on the ground around the wheels, etc. No mice this year.
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
OscarsMom2 is offline   Reply With Quote
Old 02-11-2016, 06:18 PM   #19
AquaMan's Avatar
I don't worry about mice or rodents. I have a couple of rogue cats that roam my business property and they are killing machines! I put out food for them occasionally just to keep them coming back. In the last 5 yrs, I haven't had the single trace of a mouse anywhere. I keep my GTown there in my back parking lot.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-11-2016, 06:53 PM   #20
Usually Confused Member
emm-dee's Avatar
x2 for that, although I don't have rogue cats. I live on 17 acres with about half of it dense woods and the rest pasture land. When I built my barn back in '96, and filled it with horse feed and hay, every darn mouse within 10 miles seemed to show up. Went down to the local animal shelter and got three tomcat kittens (along with certificates for free neutering) and locked them in the barn for three days (to acclimate them to and convince them they had a new home). Unlocked the "cat door" and they roam freely on the property and never seem to leave.
The mice (and rats) just plain disappeared. Each cat lasts about 10 years or so and very easy to replace. One of them likes to hang out in the stalls when the horses were there and the big animals had no problem with that. If one is keeping their RV on private property I highly recommend getting some cats. They do a good job and are maintenance free.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
trailer
