Old 03-18-2016, 06:33 PM   #1
Question How to replace the light bulb by the hitch
How do I get to the light bulb of the outside light by the tongue? I think it is burned out, at lease that's what I am going to assume first. I cannot see any type of release for the lens cover on the outside. That's probably a good thing due to moisture, etc. It has a switch on the light itself.
It is a 2011 Rockwood Mini Lite. Thanks in advance.
JHurtgen is offline   Reply With Quote
Old 03-18-2016, 08:50 PM   #2
I do not know about your unit, so take this with a grain of salt. My amber light burnt out tonight. I figured its a pop out/ pop in set up. I took a small flathead screwdriver, slide it around the bottom and popped it out. Worked like a charm.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 03-18-2016, 08:50 PM   #3
TURBS's Avatar
Look closely, there may be a little slot to get a mini flat top screw driver between the lense and the housing.
Basically it just snaps in.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-19-2016, 09:37 AM   #4
Thanks for the help. It's 28 degrees this morning in North Missouri, so I may wait for it to warm up a bit before tackling this project. I knew there had to be a way; just didn't want to tear it up trying.
Old 03-19-2016, 11:37 AM   #5
Canadian Member
itat's Avatar
If it's like this one, there is a small slot at the bottom (switch side) to let you pop the lens off.
https://www.etrailer.com/Trailer-Lig...cs/RVPL7C.html
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 03-19-2016, 07:19 PM   #6
Replace it with an LED
I've replaced all of my lights with LED s from eBay. They don't run your battery down, and they last much longer.
mnoland30 is offline   Reply With Quote
hitch, light
