Old 06-17-2016, 09:22 AM   #11
Iwannacamp's Avatar
Originally Posted by timfromma View Post
I keep a large bucket of DampRid sitting on my dining table between trips. I also put small ones in the fridge, freezer and bathroom.
one in bath and one on counter/in sink
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 06-17-2016, 09:24 AM   #12
Prime Member
My dinette is centrally located so I figured putting it there would be better.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 06-17-2016, 09:28 AM   #13
grumpy0374's Avatar
Guess I'm lucky as the Lexi is parked next to our home.
Have a 30 amp outlet outside, it stays plugged in 24/7. We use it at least 6-8 days per month with longer trips here and there. Fridge stays on. AC set to go on during real hot days (above 90). Have the foil/bubble inslolation covering all windows, which really cuts down on the heat buildup inside.
Also have a small dehumidifier sitting in shower that kicks on during humid weather.
During winter, rig plugged in 24/7 with a 30 x 12 tarp covering roof. Space heater kept at 45 degrees during below freezing temps.
I don't worry about spending the money for electric, as opposed to damage that might occur from extreme temps. I don't even think about the xtra 40 or 50 bucks spent to protect an $80 thousand dollar investment.
Grumpy
Steve & Cheryl + Charlie, Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-17-2016, 09:40 AM   #14
Don't Camp Enough
DSMURPHY's Avatar
I used DampRid years ago. Works really well. I gave up on it when I installed power outlets at the house. Now I don't have to remember to check and replace the buckets.
'2016 Rockwood 8288WSA
'2010 Tundra
DSMURPHY is offline   Reply With Quote
Old 06-17-2016, 10:05 AM   #15
Canadian Member
itat's Avatar
I store ours behind the garage at my cousin's farm about 15 minutes from our house. No cover other than for the tires and AC for the winter. I keep the battery disconnected. The day before we leave, I go over and plug it in to top up the battery and get the fridge cold. The only power source I have for it while in storage is a 15A circuit in the garage so the AC doesn't go on until we are at the campground with a 30A connection. Fortunately we don't have the extreme heat you get in Kansas or the southern US, so it's usually not an issue since it only takes about 20-30 minutes to cool down the TT. If it's hot out, you can go to the lake/pool for a dip while the trailer is cooling.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 06-17-2016, 10:33 AM   #16
actadh's Avatar
Ours is stored in front of the house and we wired a 30 amp box so it is always plugged in. Battery goes in the bedroom in winter, along with boat and trolling motor, and lawn mower batteries as it is the only room kept at a constant temperature.
In summer, I will run the AC in the afternoon if I am going to be in it, but not during the night. I leave all windows closed all the time. My previous TT had a window I forgot to close and it rained heavily. So, would rather keep it closed but for the screen door in the morning.
-Laura 2016 Shasta Oasis 18BH & 2015 Ram 1500 Hemi
actadh is offline   Reply With Quote
Old 06-17-2016, 10:43 AM   #17
JustB_Rad's Avatar
Stored on a pad next to our garage, plugged in, battery disconnected and close to level. Currently, the fridge is running...that is something hit or miss depending when we'll use it next. I forgot to turn it off Sunday when we got home, and after thinking about it, figured it would be stupid to turn it off just to cool it back down again in a couple weeks...there is nothing in it though.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 06-17-2016, 10:44 AM   #18
Mr. Dan's Avatar
Ours is on gravel under a 40'X18' shed with open ends and sheet metal on the sides 6' down from the top - leaves lower 6' open. Always plugged in to 50a service, fridge off, A/C off, ceiling vent open and maybe one window. The shed is behind our house.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 06-17-2016, 10:44 AM   #19
DaGrinch's Avatar
Every RV we've had since '08 has been parked in the driveway in the summer, plugged into 110v with the fridge running and RV stocked - completely. Always ready to go. No A/C on, just vents open.
Winter, though, is a different animal. The past 3 or so years we finally got on the list to store it at our county fairgrounds undercover. Totally winterized with the fridge emptied, propane tanks and battery removed, it sits undercover from early November to early April - typically. Our new Sunseeker will go out there this Fall.
Here's how our Flagstaff was prepared last November....
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-17-2016, 12:45 PM   #20
We store our TT near house next to carport. It is out in the Texas sun. All windows closed, plugged into 30A with A/C on 24/7. A/C thermostat set at about 85. It seems to stay cool enough inside. I place damp rid on the dining room table and in the bathroom. Tires on wood with the white tire covers.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
trailer
