Old 11-14-2015, 04:09 PM   #31
Leatherman's Avatar
Excellent, thanks for the info.
Bobby
2017 Nights Camped 35
2016 Nights Camped 34
2015 Nights Camped 18
2015 Palomino Solaire 201SS
2016 Ram 2500 Tradesman CTD
Leatherman is offline   Reply With Quote
Old 11-14-2015, 04:28 PM   #32
B and B's Avatar
Hello,
The facts have errors of common sense.
Drain the whole with the low point drains first by gravity. Thats why they are there.
Make sure you FW tank is empty as well.
Remove anode, water filter bypass HW tank, turn on winterizing valve
Then if you must use air with oil mixed in to pressure blow out your lines use 30 psi. 60 psi will blow the plastic facets apart.
I use antifreeze, pretty cheap insurance. use the big 2.5 gallon jug just to make sure!
Make sure you press in the city water spigot to get rid of any water there
Also crack open the HW tank to remove last bit of water on the other side of the valve
If you have a hose flusher on the Toilet run Antifreeze threw this as well.
Black tank rinse needs to be winterized as well, I find the vacuum breaker does a good job of draining the feed side. The other side drains on its own in my unit
Don't forget to make sure some antifreeze is sitting on the GW and BW tanks valves so they don't dry out
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-14-2015, 09:05 PM   #33
After winterizing boats I have owned over the years winterizing our very first RV was a piece of cake. I do not use an air compressor. Personal preference is to use antifreeze.
I drain the water out of the water heater, open the low point drains to drain water out of the lines and open the valve to drain the fresh water tank. When the water is drained I close the valves. Turn the handles to bypass the fresh water and hot water tanks.
I have a 5 gallon container I used for winterizing my previous boats. I put 4 gallons of antifreeze in it and put the siphon hose in it. I know 4 gallons is more than I need but when I use to pay anywhere from $250 to $300 a year to winterize my boat $10 for antifreeze is not so bad.
So I don't forget to winterize the outside shower I use that to pump antifreeze through the system. I connect the hose of the shower to the city water connection. I turn on the water pump and start opening all the faucets. Run antifreeze until comes out good and pink. The more antifreeze less diluted with water. I flush the toilet to run antifreeze through it.
I then go outside and connect the shower hose to the black water flush to get antifreeze there also. I then open the low point drains until antifreeze comes out. Close the valves again and turn the pump off. I pour what is left in drains and what is left I pour down the toilet leaving a little in the toilet to keep the seal lubricated.
My DW cleans the antifreeze out of the sinks and shower so they don't get stained. Done until next year.
djeirlessr is offline   Reply With Quote
Old 11-14-2015, 09:42 PM   #34
VinceU's Avatar
Not sure about your pressure rating. Here's a cheap ball valve from the web. The only pressure relief device on an RV is set for 125 psi. Lots of folks would come home to wet carpet if fittings failed at 60psi.
● Thermoplastic design eliminates process and atmospheric corrosion.
● Pressure rated up to 150 psi, non-shock water at 73o F
● Meets ASTM dimensions for Socket (D-2466) &
Thread (D-2464 )
● Sch 40 wall thickness
● Bi-directional: can be installed in either direction.
● Individually Bar-coded
1⁄2 - 2"
Old 11-16-2015, 01:35 PM   #35
I don't understand this part.
Iwritecode is online now   Reply With Quote
Old 11-16-2015, 02:00 PM   #36
MNtraveler's Avatar
Key points: (1) no oil; (2) no oil!
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-19-2015, 10:06 AM   #37
cogito ergo moo
Cowracer's Avatar
I guess he never heard of an oil-less compressor.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 11-19-2015, 10:26 AM   #38
Pickin' & Campin'
Tim
Or... an oil/water separator for piston compressors.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 11-20-2015, 06:08 AM   #39
Here is a link to a video of winterizing my Sunseeker. Doing a travel trailer should be very similar. Hope it helps.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 11-21-2015, 10:44 AM   #40
Traveling along
Bill and Margo's Avatar
replacing antifreeze in traps
Just wondering if its needed to replace some of the pink stuff put in the traps during the winter. Does it evaporate out?? Dry out?? The RV is in a storage lot a few miles away. We blew out the lines and put antifreeze in the traps and toilet. Just wondered if it needed "refreshing" during the winter.
Thanks for the information.
Bill and Margo
2014 Silverado 1500
2014 Tracer Air 235
Bill and Margo is offline   Reply With Quote
winter, winterize
