There are a few posts every spring regarding cracked water pumps, valves and the like.
I personally would drain the hotwater tank, turn the bypass valves to prevent antifreeze being drawn into the hotwater tank, connect a hose to the inlet side of the pump (if no winterizing kit is installed) and draw antifreeze from the jug through the pump making sure to open every faucet, tap, hot and cold, flush the toilet not to forget the outside shower until it runs pink and then if you want blow the waterlines out with air (no more than 30psi pressure) or just leave everything till spring and flush with water.
Don't forget to open the drain valve under the freshwater tank and the low point drains under the trailer.
I'm sure you can find useful tutorials on YouTube.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
