Old 11-01-2014, 12:56 PM   #1
I think i may have ruined my water pump
Well its that time of year for winterizing here on Long Island. I usually just suck antifreeze thru the pump pushing the water out of the lines and wait to visually see pink stuff coming from each location. This year with me reading so many on here blow the lines out then do the antifreeze I figured Id try it. I set the regulater for about 40psi on the compressor and like a dope I hooked up it up to the inlet side of the pump. Not thinking about and then realizing the fact this side never sees any pressure at all I disconnected it and connected to the spare port next to the outlet side. After blowing the lines clear I fed the tube into the antifreeze bottle and hooked up to the pump and turned it on. It does not turn off now after it pulls a prime. Pump constantly ran on me even when there were no faucets open. I know this thing should shut off once it pulls a good prime and the outlet line is charged with fluid. Im thinking I screwed up the pressure sensor. Guess I will be replacing the pump in the springtime hope this helps somebody else avoid a problem.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 11-01-2014, 01:16 PM   #2
TURBS's Avatar
It's just air in the line after being blown out.
Turbs
Old 11-01-2014, 01:31 PM   #3
Grn_Mtns's Avatar
Run a fixture to bleed air. The thrown works best on ours. Did you switch the water heater to by pass mode so it won't fill? Good Luck!
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
Grn_Mtns is offline   Reply With Quote
Old 11-01-2014, 02:26 PM   #4
Yeah water heater was bypassed but I guess as Turbs noted there may be air in the line from blowing it out before filling with the pink stuff. I'd assume any air trapped would keep the pump running.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 11-01-2014, 03:18 PM   #5
TURBS's Avatar
I'm guessing this is the case.
But I'm pretty sure that's your problem
Turbs
Old 11-01-2014, 06:15 PM   #6
Most pumps have "flapper" valves, that is when the pump suctions, the inlet valve opens, when it pressurizes that valve closes and the outlet valve opens. It's a pass through system and pressurizing the inlet would just open both valves simultaneously and should not hurt the pump.
joshuajim is offline   Reply With Quote
Old 11-01-2014, 06:19 PM   #7
This is good to hear I figured there was some sort of diaphram in there that I buggered up by pressurizing the inlet side. Winters up north stink! Not looking forward to the winter ahead.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
pump, water, water pump
