04-18-2018, 05:26 PM
#21
Originally Posted by Mountndream
The dealer you bought from is responsible for filling your Propane tanks
I think mountndream is on the right track of the original problem posted. Tanks are shipped empty are they not? dealer is responsible for filling. I could see a dealer skimping on propane to save a few bucks.
04-18-2018, 05:48 PM
#22
Jack of All Trades
We have a 42’ 5er, with two 30 lb LP tanks. In Ohio winters, generally with temperature in the teens, we would get about 10 days on the tanks.
The are so many variables in the usage rate of gas, inside and outside temperatures, wind (no not wind chill, that only affects animals, wind on structures effects the conduction and radiation of heat), furnace size, RV size, how it’s insulated, phase of the moon, etc., that trying to compare usage between RVs I saw almost impossible.
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
04-18-2018, 06:03 PM
#23
30# tanks weigh 55# when full but 20# weigh 15#.
I’m confused!
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
04-18-2018, 07:09 PM
#24
Dealer should have filled tanks. Many dealers are cheap. Good chance you were shorted. It is your rig. In order to avoid unpleasant situations, you need to check these kind of things. Remember to check tire pressure too.
04-19-2018, 09:44 AM
#25
I believe propane tanks can only be filled to 80% !!!
That is where they stop with our 500 gallon tank !!!
04-19-2018, 12:04 PM
#26
Boondocking Only
New/trade-in tanks are only 75% full...it's much better to just get them refilled! Last much longer & well worth the hassle and saves $$$
2014 Shamrock/Roo 21SSL
Complete LED Lighting
Off Road Package
2010 F250 Lariat 6.8 V-10 w/Timbren SES
Custom Tunes by 5 Star Tuning
Boondocking Only
04-19-2018, 12:19 PM
#27
I’m confused!
You are most likely confusing the total weight of a filled with propane cylinder (30 pounds of propane + 25 pounds of the cylinder itself)...as opposed to just 15 pounds of propane only in an exchange cylinder (net propane total without the weight of the cylinder itself)
Yes, most exchanges only put 15 pounds of propane into a cylinder designed to hold 20 pounds of propane..or 75% filled as you stated.
All of this is explained in this FAQ link that may help:
http://www.forestriverforums.com/for...ng-133760.html
2011 Flagstaff 831 RLBSS
04-19-2018, 03:07 PM
#28
I always go to places that charges by the gallon, 30# tank usually takes 7.2 gal. At least you only pay for what they put in. Also I find that Tractor Supply is almost always at least $1.00 cheaper than anyone else nearby.
04-19-2018, 03:35 PM
#29
X2 on Tractor Supply. If I had a leak the only way I would find the leaks is if the propane ran out early as I can’t smell leaking propane gas
04-19-2018, 09:30 PM
#30
Happy Camper
Electric heaters & built in electric fire places are extremely helpful keeping LP usage down.
If camping, the camp site cost covers the electric bill !!!
04-19-2018, 09:37 PM
#31
Sometimes...
Umm, yeah, if the campground covers the electric bill.
The campground where our Cherokee permanently is stationed meters the electricity. When our converter started to flake out and couldn't provide enough current to run the furnace, we ran two of those 1500 watt oil-filled radiators for five days, sometimes both on, and sometimes one on 1500 and one on 600. And our usual $7.00 electric bill was $78.00. Propane, using the tanks I port from Costco would surely have been less expensive.
Larry
04-20-2018, 08:25 AM
#32
Larry
It is often cheaper to turn down the heat,,, and put on some sweets !!!
We live in our sweats in the winter !!!
Hoping for some Spring weather soon,,, so we can put our sweats away !!!
04-20-2018, 08:38 AM
#33
I like the way you think. I have been putting on my sweat pants and then put on the sweets. I'm never cold.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
04-20-2018, 08:44 AM
#34
Too Cold to type this morning !!!
04-20-2018, 09:21 AM
#35
No comment
[QUOTE=Wolverine 1945;1788386]It is often cheaper to turn down the heat,,, and put on some sweats !!!/QUOTE]No comment.
04-20-2018, 09:23 AM
#36
No comment
No comment.
