Old 07-16-2013, 04:53 AM   #11
Steve Jackson
sideout1961's Avatar
Originally Posted by bikendan View Post
using one chock ain't gonna do it.
you need tandem wheel chocks on both sides. this, along with the stabilizers, will take most of the movement out.
be careful about adding jacks. if you have an ultra-lite frame, you could damage the frame.
I use the four chock method and it works well. I use a rubber mallet and when I put the chocks down I give them a couple of whacks to seat them under the tires and it seems to work for me.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 07-16-2013, 06:00 AM   #12
Toad Haul's Avatar
X2 on the step supports. The wife calls me moose when I step up into the trailer, causing it to rock big time. Putting the supports under the bottom step makes a huge difference. Great $14 investment.
Darren, Donna & The Wieners
Toad Haul is offline   Reply With Quote
Old 07-16-2013, 06:42 AM   #13
Additional jacks should only be placed on the suspension framework only, it is the 2x4 tubing framework to which the suspension is actually attached.
Old 07-16-2013, 06:59 AM   #14
Indeed. They should never be placed under the camper frame without some modification to distribute the load, and should not be used to try and lift the camper. Stabilize only with moderate pressure, just as with the rear jacks.
Campers with the rubber torsion axles have a subframe mounted under the "I-beams" of the camper frame, and that is what any extra jacks should be mounted to. Ideally, one would mount them in the center, to distribute the load, and considerable jacking force could be used there, but they would be difficult to access. The second best place would be at the front of the subframe, but much less jacking force would be desirable, as the load would not be as well-distributed.
Anyone with an ultralight frame should take a really good look at it, and that would be enough to convince you to be careful with it.
bakken is offline   Reply With Quote
Old 07-22-2013, 01:03 PM   #15
How do I find out if I have an ultra light frame?
KathyJB is offline   Reply With Quote
