Old 08-24-2011, 03:48 PM   #11
I'll try to get some pictures later today. I got the ball-and-socket fittings at a handyman supply center, where they have stuff to make stuff. Hydraulics, sprockets, bearings, tools, trailer axles, pretty much everything you need to build anything. My favorite store!
Old 08-24-2011, 09:04 PM   #12
Here are a couple of pictures showing my version of the steady-fast system. I welded a 1x2 rectangular steel tube between the leg towers so I had a solid attachment point for the stabilizer bars, plus it adds strength to the legs.
The side bars are mounted (at the back) to the camper frame. The mounts are bolted solidly to the frame. I had to remove the basement door opening tubs (those black plastic tubs by the door) to gain access to the frame, but that was easy.
The ball-and-joint ends come in many sizes, I just got some that had bolt ends about the same size as the holes in the legs.
There is virtually no slack in the system anywhere, and is very quick to use. And it looks a lot slicker than the real Steady-Fast. I don't know why they made it so complicated, other than they could charge more.
ID:	7603   Click image for larger version
Old 08-24-2011, 09:53 PM   #13
Originally Posted by bobsquarepants View Post
I have the BAL X-Chocks, they reduced movement quite a bit...but I'm still not happy. So I have ordered a set of JT Strong Arms so hopefully those will work. Seems to me Iggy on the forum here has the Steady Fast system maybe he can chime in. I decided against the kingpin tripod as I have read mixed reviews, and it's another piece of gear to carry and stow.
i was going to type up a reply to the original post.....but bob pretty much said the exact same thing i was going to
i have the bal xchocks.....they serve better as a wheel chock than they do as a stabilizer. i didnt notice much difference
a guy i always camp with has the strong arms. it is literally night and day difference. worth every penny
never owned a kingpin tripod/bipod....but all i hear are mixed reviews. and like bob said....it take up ALOT of room
2006 Cherokee Wolfpack 295WP - 2 Interstate U2200 6v, 1500w inverter, clear lens LED clearance and tails, Starlight Revolution 300 lumen LEDs EVERYWHERE!
2012 Dodge 2500 - deleted and tuned by H&S performance
Bocephus is offline   Reply With Quote
