Old 05-31-2011, 06:32 PM   #1
dretired's Avatar
igloo 12 volt cooler
I recently bought a used igloo 12 volt cooler. My question is... can i use a pig tail hookup once at the campground on the TT battery . i would be plugged into the campgrounds electric. Will it still be enough charge on the battery ???
dretired is offline   Reply With Quote
Old 05-31-2011, 06:36 PM   #2
sherdep's Avatar
yes you will be fine - as long as it is either hooked up to the tow vehicle or plugged into shore power the battery will charge
you should have a cigarette lighter style power adapter in the trailer somewhere so you dont have to use the alligator clips to the battery for the cooler - remember not to hook it up backwards or it will become a warmer LOL
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-31-2011, 06:43 PM   #3
dretired's Avatar
Sherdep... I have NOT seen a cigarette style plug in port anywhere inside or outside the trailer..
Old 05-31-2011, 06:44 PM   #4
sherdep's Avatar
you have a pop up dont you?
or is it a 2306? cant remember
Old 05-31-2011, 06:49 PM   #5
dretired's Avatar
No. I have a 2009 26rlss Puma TT
Old 05-31-2011, 06:57 PM   #6
sherdep's Avatar
I am way off base on that one then LOL
Not sure where there would be one then - guess you are using pig tails off the battery then LOL
12 volt
