Old 04-25-2009, 09:07 AM   #11
Originally Posted by eandsphotography View Post
I have a flagstaff 831krss. I am currently at the campground for the weekend and have absolutly no water pressure. Ive checked everything i can think of but no luck. Ive checked the hose for kinks, washers, clogged screens, took the water pressure regulator off all with no luck. Ive checked the water filter and even took the filter out of the canister and its still not any better. It just seems like something is kinked. Thats the type of pressure im getting. At tge campground spigot the pressure is good or at least good enough to give me more then what im getting on the inside of the trailer.
Anything you can think of would be great.
Erik
Would you please report here what you did to fix the problem? I have the same model camper as you and although I have not run into this problem, I would appreciate the information, just in case.
I hope you resolve your problem, it sure can bum out your trip to encounter problems like this. How do you like the camper otherwise?
2008 Flagstaff 831KRSS
Dodge Ram 1500
dufchick is offline   Reply With Quote
Old 04-25-2009, 10:07 AM   #12
Well,i think the problem just was the campground water pressure. A guy pulled into the site next to me last night so i asked him to check his pressure and he said his was weak also. I ended up just filling up the fresh water tank and using the trailer water pump which gave me better pressure,if that isnt pathetic!!!!!
anyway,just got home and im going to hook up my water from the house just to double check that my city water inlet isnt clogged or kinked somewhere but after talking to the guy at the next site im pretty sure that it was just low pressure at the campground.
What kind of threw me off though is that when i opened the faucet at the site without a hose attached ,it seemed pretty normal as far as the flow.
eandsphotography is offline   Reply With Quote
