Old 10-23-2014, 11:36 AM   #1
Installing a 5th Wheel Cover Without Climbing on the Roof
Thinking of purchasing and installing a custom fitted cover for our new 8528IKWS Flagstaff 5th wheel BUT do not want to climb on the roof. On sale now at CW.
Does anyone install a cover using ladders? Possible?
Would it be possible to attach the two corners of the cover to long wooden (or other) poles and work it from the rear to the front?
Any other ideas would be welcome.
Have seen the many suggestions for protecting sharp corners/edges using tennis balls or swimming noodles.
Looking for your suggestions regarding installing without climbing on the roof.
MartyQ is offline   Reply With Quote
Old 10-23-2014, 03:09 PM   #2
I would say no from my experience. These covers are heavy and bulky.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-26-2014, 12:27 PM   #3
Sharon455's Avatar
I used to see Camping World ads for the Ezee Up RV Pulley Lift, but a quick Google now only shows references in other forums and a few sales prices for the cover. If I recall, the pulley was attached to the top of the RV ladder, but since I don't have a cover I never read the full ad info. I suspect it was designed just to get a bulky cover up on the roof, but then you would still need to get up there to do the work.
Happiness is just a ride away!
Sharon455 is offline   Reply With Quote
Old 10-26-2014, 02:51 PM   #4
davel1971's Avatar
being at least 40 lbs, there is no way you could safely handle that from a ladder. You would be safest on the roof
David & Lynn
Old 10-26-2014, 03:49 PM   #5
Ford Idaho's Avatar
If one is capable a backpack frame with the cover strapped to it.
Gold Nugget Army Surplus: Backpack Frames
Roll the cover out on the ground then fold and roll it inside out so that once on the roof you just unroll it front to back unfold from the center to outside edges.
You could tie some rope to the corners to pull the sides down from the ground if you want.
5th wheel, cover, roo, roof, wheel
