Old 11-30-2013, 07:10 AM   #1
yelhelp's Avatar
Send a message via AIM to yelhelp
Insulation Help Needed
We have a Salem Toy hauler and plan on spending the winter in Texas this year , but can not leave until 1st of Jan. I have tried to insulate under the TT with 2 " insulation but have not found a way to protect the water and holding tanks short of building a box under the trailer (wow) anyone ever tried this? I have lived in the north most of my life and doing this for a house no big deal , but with an RV /TT I think this may not be so easy.
yelhelp is offline   Reply With Quote
Old 12-01-2013, 11:54 PM   #2
Dave_Monica's Avatar
Here's a thread posted here in 2010 that may answer some of your questions... Setting up for long term stays (years)
Dave
Old 12-03-2013, 08:15 PM   #3
Capsfloyd's Avatar
A few questions , I assume your water holding tank and sewer tanks are heated?
If so then buy the blue or pink stray foam board and box in tanks , the sell silicone to glue the seams or use wood screws
Next heat trace water lines and insulate with 3/4"
Foam pipe insulation
Buy thin plywood and screw the foam board to plywood and skirt the trailer
On the inside open cabinet doors where there are any plumbing lines so they will get heat
Your sewer should be fine , hook up lateral line to sewer connect , keep valves open
We live in Texas also , where are you going to be ?
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 12-04-2013, 05:51 AM   #4
yelhelp's Avatar
Thank you
This is some great ideas I have most of the bottom done with 2 inch blue , but gluing and heat tape maybe my next step. I may run out of time here we are heading that way in Jan if all goes well.
