The size of the standard TV / TT Aux wire combined with the length of the aux wire result in a voltage drop that usually at best provides sufficient power to overcome the parasitic draws. If you upgrade the gauge of the wire you can get some improvement. If your fridge/ inverter consuming 800W, you will be drawing 0ver 60A from the Battery. If you assume the fridge runs 33% of the time, you need about 20A added to the battery while driving. If the resistance in the path from the TV fuse block to the battery is one tenth ohm, you will lose 2V so the voltage from the TV to the battery will be at best 12V.
Unless you upgrade the wire significantly the TT battery will not be charged when running the fridge.
Originally Posted by bikendan
Just that depleted batteries may not get fully charged.
You need to test your 7 pin connector, for how much juice is coming from the charge wire.
