Old 06-22-2008, 06:00 PM   #11
MRimmer's Avatar
My manifold was not cracked and all they are doing is adding the sheilds and switch to shut it down if overheat and supposed protect the burner incase of a crack.
Like I said looks mickey mouse to me.
Mike
MRimmer is offline   Reply With Quote
Old 06-22-2008, 06:04 PM   #12
OK, correct me if I am wrong, are these units loosing Ammonia? and if so how does this fix it?
Old 06-22-2008, 06:08 PM   #13
MRimmer's Avatar
It is supposed so I hear to keep it from getting to the burner.
Based on what I see it appears it should shut (thermal switch) it down before it gets hot enough to fail and cause a fire.
I really wish I knew more.
Old 06-22-2008, 06:18 PM   #14
It seems to me that they need to fix the leak. If an A/C unit looses 10% of it's charge, by law the unit has to be repaired or replace. This is a strange law, but if it is a very small leak it can be recharge and no demands are made to replace it.
Old 06-22-2008, 08:47 PM   #15
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I'm glad the fridge in my Park Trailer is a Whirlpool.....
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 06-23-2008, 08:28 PM   #16
I made a vist to my dealers to day with my camper, the info I got is that Dometic is taking precautions. Dometic sees a problem that could come up IF the manifold cracked because of the location of the componets. The service manager told me that he has not seen any problems on any of the recalls where people have had damage due to this issue. Dometic is trying to seperate the ammonia from the two red wires that are on the cannister and the cannister it self. The list of things that Dometic posted as to what to look for would be a resalt if somthing were to happen to the system, this would give you and Idea where it is coming from. I suggest to check with your service department and see if they come up with the same conclusion.
Old 06-24-2008, 07:42 PM   #17
I'm with RockWood06 - its not really a repair, Its just a safety thing so TT won't blow up and burn to ground. The manifold can still crack!
Wolfgang is offline   Reply With Quote
Old 07-13-2008, 10:58 PM   #18
Rockwood 06:
You hit the nail on the head with your question: "What about the cracked manifold?" This Dometic recall was a joke!.
We had ours done and had to pay an extra $40 for the trip charge, because our unit is permanently parked about 25 miles from the dealership with no way to get it there!
So, I, for one, am not a happy camper! This should have cost me ZERO dollars. It was a half day inconvenience for me, too, for a couple of silly sheet metal shields and junk. I DOUBT SERIOUSLY that these shields will stop a real fire if I get a crack in my cooling unit.
I think DOMETIC is PLAYING THE ODDS HERE FOLKS. But, the odds involve your trailer going up in flames! I am not joking about that. When I asked the Dometic recall line, I even got conflicting info - one person said don't run it on AC power, just run the fridge on gas - the other said, 'no, don't do that, it would be much worse' - 'dont even use it at all until you get the recall done'. So, I jumped through hoops and paid extra to get it done. Hah! What a joke that recall was!
Bottom line: If you TRAVEL with your RV and your fridge is subjected to bouncing and bumping all the time and is not PARKED all the time, you should DEMAND that Dometic replace the entire cooling unit and threaten to SUE THEM if they do not do so. The rest of us are playing the odds that the CRACK doesnt happen to us or that these flimsy sheet metal plates will stop a fire.
Heck, if the side of my trailer catches on fire, due to a refrigerant leak, DOMETIC will be sued. No doubt about it. I just hope those emergency windows work well.
Better stock up on portable fire extinguishers, folks, just in case.
walk_the_walk is offline   Reply With Quote
Old 07-14-2008, 10:43 AM   #19
My fridge quit working on AC power, but it works on gas. Does that have anything to do with the recall that I never got???? Randy
Old 07-18-2008, 02:48 PM   #20
need new refrigerator
We dropped off our 25' 02 rockwood for the recall kit but the dealer says the kit won't fix it, it needs a new cooling unit. I'm natually pessimistic so how do I know they are not pulling a fast one here.
Assuming the frig really is dead, any suggestions on a new one? I've read good reviews about Norcold as far as how they stand behind their products.
Anyone know off hand the size of the frig in our TT so I can research online a bit right now, the TT is at the dealer.
Thanks, Brian
brianR is offline   Reply With Quote
